Which Red Top battery for a MKIV
Wez
Hey All,
Would a Varley Red Top 8 work on a MKIV :-
Voltage=12
Capacity=7Ah
Weight=2.7kgs
Dimensions=138x86x101mm
Terminals=M4 female
Cranking current (20°C for 5secs)=200A.
Or should I go a little bigger to the 15 :-
Voltage=12
Capacity=14Ah
Weight=5.0kgs
Dimensions=200x77x140mm
Terminals=M6 male
Cranking current (20°C for 5secs)=400A.
The stock cranking ampage is quite low isn't it? I can't recall the exact figure but it's much less than 200A isn't it?
Unless you're running some electronics with major current draw the stock alternator should be able to keep up with with ease provided it gets a good run when it's used.
I am sure I read in the battery FAQ that less than 200A is required, looks like the super small one should do the trick :D
i think mine is a varley red top 35 if that helps??
Cant see a 35 but here is the info the 30 :-
Voltage=12
Capacity=26Ah
Weight=9.0kgs
Dimensions=250x97x156mm
Terminals=M6 male
Cranking current (20°C for 5secs)=685A.
Its 6.3kg more than a Red Top 8 ;)
I'd use a 40, but you may well get away with a 30. You know these things won't stand fast charging, so never let it get discharged, jump start and let the stock alternator ram a huge amount of amps into it!!! I can do good prices on Red Tops and have some in stock.
Arent they a bit large Chris?
Would the be happier if they are disconnected between use?
These Braille batteries look good :-
http://www.brailleauto.com/
Braille B106C Carbon Fiber Sealed Battery
Weight: 6 lb/2.8kg
Volts: 12 AmpHr: 10
Cranking Amps: 527
L: 5.8" W: 3.3" H: 4.2"
Uses: Ultimate in Lightweight Performance. Small displacement motors.
Braille B14115C Carbon Fiber Sealed battery
Weight: 11.5 lb/5.2kg
Volts: 12 AmpHr: 15
Pulse Cranking Amps: 904
Exterior Size L:5.8" W:3.3"H:5.9"
Uses: Sport Compact Vehicles Street Use Warm Climates; 4 & 6 cylinder Race Vehicles
Braille B3121 Carbon Fiber Sealed battery
Weight: 21 lb/9.5kg
Volts: 12 AmpHr: 31
Pulse Cranking Amps: 1380
Exterior Size L: 6.6 " W: 5.2 " H: 6.8 "
Uses: All Vehicles Street Use Warm Cold Climates; All Race Vehicles; CustomAudio; EV Application
POS, a good way to get a none starting engine :) Red Tops are aircraft certified, the buyers of the Braille ones need to be certified, (IMHO....) :) Seen 4 race car owners running round like headless chickens trying to cock up a battery that works with those things, IN THE LAST MONTH ALONE.
:lol: you dont rate them then.
What about these Voltphreaks batteries Chris:D
http://www.voltphreaks.com/
https://s.p10.hostingprod.com/@www.voltphreaks.com/ssl/catalog/product_info.php?cPath=1_5&products_id=55
Item Specifications
Model Number VP550
Nominal voltage 12.8V
Cranking Amps (CA) 550 amps
Cold Cranking Amps (CCA) 300 amps
reserve capacity (RC) 22 minutes
Capacity 12Ah
terminal type 5/16" gold plated ring
working temperature -22°F to 140°F (max 185°F)
dimensions 8.3x5x3 inches (not including terminals/flanges)
weight 4.25 pounds
It says US shipping only, but I contacted them and the delivery is only $40
A good few folk over in the beemer forum have been using these with full electrics and were impressed, pricey but I've spent more on carbon to lose the weight than what I would on this 1.92kg!!
