running bad
daz
going to the nw meet to nite wen i put my foot down at 70 mph .4 revs the car jerkin it want too go it hesitate it going it never done this before only work i had done too the car is bpu by chris wilson it been great up to now :( boost gauge is fitted it shows 08 .
any ideas :Pling
cheers daz
Oh yes, I forgot to add some help :D, I've just sorted a serious missfire by checking the pins on each of the coilpacks, I'm sure there's a FAQ in FAQs detailing how to refurb the connectors & it also explains in there to adjust the pins on the coilpacks themselves
The people you need help from most will be reluctant to help with all that txt speak bud, just a friendly suggestion esp when posting in Technical :)
sorry not the best on pc . old school ;)
I think I changed one or two coil pack connectors, the others looked fine, but worth a check. Did I change plugs, or was yours the one with the colder plugs ready in there? I would have to dig the invoice out to check. I can have a quick look at it next week if you get stuck.
You must have supplied them, I only use NGK myself. maybe worth pulling the plugs and having a look at them, if you are happy with that?
i did supplied ik22. which NGK should i use shall i put them in try it or come and see you on which day so you can have look at the car:Pling:
cheers daz
  • 2 weeks later...
The IK22 should be OK, but some people find they are bit fragile. I keep the NGK's in stock, probably best you pop it over, i can give you some dates if you bell me later next week. I have a lot of catching up to do after my mum's illness and demise. Cheers.
hi chris we spoke last week . wot the best time for me too
bring the car too you on satday 2nd august , cheers daz
You'll need to contact me on say Thursday, i am fairly confident i can look at it briefly on Saturday, depends on some personal stuff i am still sorting. If you are just going to leave it 9better for me, to be honest), any time after 8.00 AM and before 4.30 PM should be ok. Just ring me nearer the time though please Daz.
  • 2 weeks later...
hi chris did you find out wot was wrong with the car:Pling:
any ideas :Pling
cheers daz
got me car back now . hesition prob was a leak on the sequential system and found a possible injector prob or cured now running awsome again thanks to chirs wilson :D
now going for a drive
