p3te Posted July 13, 2008 Share Posted July 13, 2008 Im after getting a new set of plates for my car satndard size but unsure on what the standard size for a uk spec rear plate is, ive seen a few different sizes and just have the 520 x 111 on at the mo? Quote Link to comment Share on other sites More sharing options...
JustGav Posted July 13, 2008 Share Posted July 13, 2008 Standard UK plate will be the same as most cars have (Not just supras). Have a look on the DVLA website Quote Link to comment Share on other sites More sharing options...
p3te Posted July 13, 2008 Author Share Posted July 13, 2008 so was the rear plate 520 x 111 as standard as well and not larger to fill the space? Quote Link to comment Share on other sites More sharing options...
p3te Posted July 13, 2008 Author Share Posted July 13, 2008 just watching the original test drive it has a larger rear plate as well? http://youtube.com/watch?v=2iBdlistioc Quote Link to comment Share on other sites More sharing options...
Paul Posted July 13, 2008 Share Posted July 13, 2008 Standard UK plate is larger than normal, fills the space:) Quote Link to comment Share on other sites More sharing options...
p3te Posted July 13, 2008 Author Share Posted July 13, 2008 i thought so , whats the size of it? Quote Link to comment Share on other sites More sharing options...
Paul Posted July 13, 2008 Share Posted July 13, 2008 Dunno mate, I'll measure it later if you like. Quote Link to comment Share on other sites More sharing options...
p3te Posted July 13, 2008 Author Share Posted July 13, 2008 if you dont mind , just id like to get a set of the original size plates Quote Link to comment Share on other sites More sharing options...
hadyn Posted November 16, 2008 Share Posted November 16, 2008 Did anyone get the measurements of a standard UK spec rear plate? It is larger than a normal rear number plate. Quote Link to comment Share on other sites More sharing options...
Paul Posted November 16, 2008 Share Posted November 16, 2008 I measured mine and it's : 530/535mm x 150mm Quote Link to comment Share on other sites More sharing options...
hadyn Posted November 16, 2008 Share Posted November 16, 2008 thank you Quote Link to comment Share on other sites More sharing options...
hadyn Posted November 16, 2008 Share Posted November 16, 2008 So a 534mm x 152mm plate should be OK? Quote Link to comment Share on other sites More sharing options...
Paul Posted November 16, 2008 Share Posted November 16, 2008 So a 534mm x 152mm plate should be OK? Yeah, that would fit. I guess the slight difference depends on where you buy from. Quote Link to comment Share on other sites More sharing options...
hadyn Posted November 16, 2008 Share Posted November 16, 2008 Yeah, that would fit. I guess the slight difference depends on where you buy from. http://www.craigsplates.com/ Quote Link to comment Share on other sites More sharing options...
