Terminator Posted July 13, 2008 Share Posted July 13, 2008 I have two spare Walbro pumps. A 341 and a 342(Now Sold). The 342 fits JDM hangers, the 341 fits UK/US hangers. My hanger is custom so fitting different model pumps was never an issue for me. The 342 JDM pump was used for static tests of my new fuel system and 20 road miles. None of the fitting kits parts were used. 342 Filter Fuel filter of 341 pump, that ran in my car for 15000 miles. Excellent condition. Both pumps for sale. Walbro 342 JDM pump, used but as new, for sale at £60 posted in UK SOLD Used Walbro 341 UK pump £45 posted in UK.Price Now £28 posted. This pump is in perfect working order and has it's own brand new fitting kit. Link to comment Share on other sites More sharing options...
Terminator Posted July 13, 2008 Author Share Posted July 13, 2008 342 JDM pump now sold subject to payment. Link to comment Share on other sites More sharing options...
kint Posted July 13, 2008 Share Posted July 13, 2008 pm me please if that doesn't go through, as I'm looking for a pump to fit j-spec for bpu Thanks Link to comment Share on other sites More sharing options...
Terminator Posted July 15, 2008 Author Share Posted July 15, 2008 The only reason the 341 does not fit is it faces the oposite direction. If you cut the fuel feed pipe shorter, use a longer piece of fuel hoes a jublee clip to clamp the pump to the hanger, you can rotate the pump through 180 degrees to make it fit. If you want a perfect stock fit that is virtually plug and play, then the 342 is the one to go for. I have fitted both pumps to JDM hangers with out issues. Link to comment Share on other sites More sharing options...
Terminator Posted July 21, 2008 Author Share Posted July 21, 2008 342 JDM pump SOLD 341 UK pump still for sale. Link to comment Share on other sites More sharing options...
Terminator Posted October 24, 2008 Author Share Posted October 24, 2008 UK fit pump still available, may do as a spare. Can be fitted to a JDM hanger with a Jubilee clip so will fit JDM cars. Plug and play fit for UK car. Reduced to £28 posted to UK mainland Link to comment Share on other sites More sharing options...
Terminator Posted May 5, 2009 Author Share Posted May 5, 2009 UK pump still available. Price now £28 posted in UK Link to comment Share on other sites More sharing options...
johnd-mkiv Posted May 5, 2009 Share Posted May 5, 2009 hey mate ill take the uk pump, will it be enough to run 650cc injectors for my 1jz project Link to comment Share on other sites More sharing options...
Terminator Posted May 5, 2009 Author Share Posted May 5, 2009 I think it would depend on a number of factors. To get the most out of the pump or any pump for that matter, I would only use the stock pump power supply wires to trigger a relay that feeds power direct from the battery in heavy gauge wire. This is where a boot battery comes in handy. Size of fuel lines and fuel pressure used also have to be factored in. I would say that the single Walbro is too close to is limits at 43.5psi baseline pressure to be used with 650 injectors. It is well with in it limits with 550cc injectors. Others may have a different point of view, but I like to build in safety margins when it comes to fuel delivery. Link to comment Share on other sites More sharing options...
Terminator Posted May 6, 2009 Author Share Posted May 6, 2009 Talked my self nicely out of that sale, so still available. Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted May 6, 2009 Share Posted May 6, 2009 If it fitted a jspec I'd be on it (but then so would everyone) Link to comment Share on other sites More sharing options...
Terminator Posted May 6, 2009 Author Share Posted May 6, 2009 I think John's issue was related to flow rate not how it fitted. It does fit if you don't use the rubber locator but fasten it with a jubilee clip, that is how it was fitted in my car. The internals are the same, same flow same, current draw the same, it is just the location of the filter and intake that are different. Link to comment Share on other sites More sharing options...
johnd-mkiv Posted May 6, 2009 Share Posted May 6, 2009 hey mate sorry just got in from work if I double these up will it be a safer bet Ill be running this system in a bmw so ill have to make up a new hanger anyway the battery will be located in the boot too Link to comment Share on other sites More sharing options...
Terminator Posted May 8, 2009 Author Share Posted May 8, 2009 sold Link to comment Share on other sites More sharing options...
