Guest brko Posted July 12, 2008 Share Posted July 12, 2008 I have a aero top and some wet problems. The drivers side is leaking when raining hard, which is a common thing in uk. It leaks exacly in the corner where the windscreen and roof meet. I think it is rubber strips/whether black rubber thingy the problem. There are three parts of rubber, the sides and the Main one that goes in the front and at the sides. I bought this one but how do I fit it???????? anyone done it yet??? Quote Link to comment Share on other sites More sharing options...
TRACIE_LOU Posted July 12, 2008 Share Posted July 12, 2008 we have same problem were did you buy the rubbers from id like to give this a go Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted July 12, 2008 Share Posted July 12, 2008 Nic does the full set. I've bought one from him, and its very easy to fit, as long as you feel comfortable taking the roof apart! Quote Link to comment Share on other sites More sharing options...
Guest brko Posted July 13, 2008 Share Posted July 13, 2008 we have same problem were did you buy the rubbers from id like to give this a go I bought it from Toyota it cost about £75 and the sides about £65 each. not cheap Quote Link to comment Share on other sites More sharing options...
JohnHandy Posted July 21, 2008 Share Posted July 21, 2008 I have a aero top and some wet problems. The drivers side is leaking when raining hard, which is a common thing in uk. It leaks exacly in the corner where the windscreen and roof meet. I think it is rubber strips/whether black rubber thingy the problem. There are three parts of rubber, the sides and the Main one that goes in the front and at the sides. I bought this one but how do I fit it???????? anyone done it yet??? Silly question......... Do you bolt the roof up correctly? Back bolts first then the fronts? If not done this way the top will leak. Once you have fitted the new rubbers rub down with a smal amount of silicone spray once a month like it's your new religion. Quote Link to comment Share on other sites More sharing options...
