Guest DrifterWanaB Posted July 12, 2008 Share Posted July 12, 2008 (edited) Hello all, The previous owner has put some clear indicators in the front bumper, when i indicate the indicators flash too fast like what happens when you have a bulb out, but all bulbs are working. I think this has some thing to do with the resistence/capacity of the bulbs propbably in the new front indicators is too low? any suggestions to get them right? Edited July 12, 2008 by DrifterWanaB (see edit history) Link to comment Share on other sites More sharing options...
jaymdee Posted July 12, 2008 Share Posted July 12, 2008 You sure all the bulbs are working? I had this once and found i had a side light bulb come out a bit and it needed to be pushed back in Link to comment Share on other sites More sharing options...
Guest DrifterWanaB Posted July 12, 2008 Share Posted July 12, 2008 You sure all the bulbs are working? I had this once and found i had a side light bulb come out a bit and it needed to be pushed back in yeah they are all working, both sides do it aswell Link to comment Share on other sites More sharing options...
merckx Posted July 12, 2008 Share Posted July 12, 2008 Like you say the wattage of the bulbs is probably too low. I'm not sure if the pre-facelift and facelift cars use the same bulbs. Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted July 12, 2008 Share Posted July 12, 2008 Are they LED bulbs? Link to comment Share on other sites More sharing options...
JustGav Posted July 12, 2008 Share Posted July 12, 2008 Are they LED bulbs? Exactly what I was thinking, probably find the side repeaters are LED, when using LED a suitable resistor should be put in line to maintain the correct flash speed. Link to comment Share on other sites More sharing options...
ivan Posted July 13, 2008 Share Posted July 13, 2008 Looks like you need one of these: http://www.ultraleds.co.uk/complete-flasher-unit-stops-fast-flashing-indicators-p-978.html?osCsid=9108306997dc94a2fd22b1c126244f84 Link to comment Share on other sites More sharing options...
merckx Posted July 13, 2008 Share Posted July 13, 2008 That's handy, I didn't know that these were available. Link to comment Share on other sites More sharing options...
Stan Posted July 15, 2008 Share Posted July 15, 2008 A cheaper option would be: http://cgi.ebay.co.uk/Load-resistors-LED-indicator-stop-tail-light-bulbs_W0QQitemZ220255575670QQcmdZViewItem?hash=item220255575670&_trksid=p3286.m14.l1318 That's what I used when I put LED bulbs in my prelude, you just splice one side into the +ve and one into the -ve wire that goes to each bulb you've replaced Link to comment Share on other sites More sharing options...
