Paul372 Posted July 12, 2008 Share Posted July 12, 2008 i am going to get my auto tt supra fully serviced, i ve got trd oil filter, nkg spark plugs but i need to get a fuel filter is there anything else i need because am supplying all the parts, and what engine oil do i need to use and also what trans oil and diff oil please cheers, nearly forgot and how much litres of oil do i need to get Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 12, 2008 Share Posted July 12, 2008 IMO theres no need to get a TRD filter for your car, the standard Toyota one is fine and prob alot cheaper Engine oil is a matter of opinion, a decent semi synth should see you right. As for auto box and diff, I only ever use Toyota type 4 in my 'box, not cheap but the best. Diff, is it lsd or not? That will have a bearing on the choice Quote Link to comment Share on other sites More sharing options...
edge Posted July 12, 2008 Share Posted July 12, 2008 Its all in the tech info section on the forum. Search button is your friend - do a search for oil, fluids, capacity etc etc. Use oem parts for a service if possible. Quote Link to comment Share on other sites More sharing options...
Paul372 Posted July 12, 2008 Author Share Posted July 12, 2008 cheers is there anything else i need to get for the service Quote Link to comment Share on other sites More sharing options...
Nic Posted July 13, 2008 Share Posted July 13, 2008 cheers is there anything else i need to get for the service When was the oxygen sensor last changed? Well worth fitting a new one with the price of fuel as it is. What condition are the brake pads in? A quality set of pads, decent fluid and stainless steel brake lines will make a big difference. See FAQ for info: http://mkivsupra.net/vbb/showthread.php?t=56684 Quote Link to comment Share on other sites More sharing options...
Paul372 Posted July 15, 2008 Author Share Posted July 15, 2008 i ve just replace the discs and pads with 3g groved discs and new endless pads i also fitted goodrigde braided hoses while i was at it and replaced the brake fuild so all good there Quote Link to comment Share on other sites More sharing options...
