Guest Blue_RZ Posted July 12, 2008 Share Posted July 12, 2008 hi guys my mates supra is turning over but not firing up, have checked the battery and even jumped it from a good one still no joy, no clicking noises of any sorts.. does anyone have any ideas Link to comment Share on other sites More sharing options...
Guest Nicholas Posted July 12, 2008 Share Posted July 12, 2008 have you tried another igniter pack? check the connetions to it before replacing. Link to comment Share on other sites More sharing options...
supramkivcork Posted July 12, 2008 Share Posted July 12, 2008 starter motor ? contacts on the starter motor ? Link to comment Share on other sites More sharing options...
JustGav Posted July 12, 2008 Share Posted July 12, 2008 No clicking at all? Check your fuses. Do you get dash lights or anything. Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted July 12, 2008 Share Posted July 12, 2008 TT or NA as well. If it was an NA id just whip a HT lead off and check for spark so you know you have that. Link to comment Share on other sites More sharing options...
Guest Blue_RZ Posted July 12, 2008 Share Posted July 12, 2008 Thanks for the reply guys, its a TT manual and all the dash lights come on! do you think it could be the ignition amp that is goosed? Link to comment Share on other sites More sharing options...
Lee P Posted July 12, 2008 Share Posted July 12, 2008 Check the coolent temp sensor conections, if they are broken the car will not start. It is located in the water neck pipe joined to the top rad hose. Link to comment Share on other sites More sharing options...
Swampy442 Posted July 12, 2008 Share Posted July 12, 2008 Also is it MAP or MAF? If its map and the plug's dodgy it wont start. Is there any fuel in it.... Link to comment Share on other sites More sharing options...
Guest Blue_RZ Posted July 13, 2008 Share Posted July 13, 2008 will check the map or maf and coolant temp sensor tomorrow thanks guys Link to comment Share on other sites More sharing options...
RobSheffield Posted July 13, 2008 Share Posted July 13, 2008 Is it turning over at all? A lot of folks in this thread seem to think its spinning but not firing. I read your responses and took it that it wont do anything at all. Link to comment Share on other sites More sharing options...
Guest Blue_RZ Posted July 13, 2008 Share Posted July 13, 2008 its turning but not firing up, Link to comment Share on other sites More sharing options...
Guest Blue_RZ Posted July 24, 2008 Share Posted July 24, 2008 checked igintion amp, all fine, crank sensor is fine also but still not firing up any ideas ??? Link to comment Share on other sites More sharing options...
Rayman Posted July 24, 2008 Share Posted July 24, 2008 Try checking for error codes, is it cranking but not catching and firing? Could be fuel pump related if that. Link to comment Share on other sites More sharing options...
movistar Posted July 24, 2008 Share Posted July 24, 2008 Eliminate if you not getting either a spark or fuel to start...have you checked the cam belt? Link to comment Share on other sites More sharing options...
Guest Blue_RZ Posted July 24, 2008 Share Posted July 24, 2008 cambelt is fine, Link to comment Share on other sites More sharing options...
Guest Blue_RZ Posted July 25, 2008 Share Posted July 25, 2008 started this morning, dont know what happend thanks to everyone who helped Link to comment Share on other sites More sharing options...
