123tom123tom Posted July 11, 2008 Share Posted July 11, 2008 If one of the blades on a turbo is chipped at the corner will it still work properly, am not talking like half a blade a mean like 2mm-3mm chipped off the corner.... Quote Link to comment Share on other sites More sharing options...
uk-rich Posted July 11, 2008 Share Posted July 11, 2008 it will unbalance the turbo, which will cause premature seal wear Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted July 11, 2008 Share Posted July 11, 2008 Pics be best... Quote Link to comment Share on other sites More sharing options...
Branners Posted July 11, 2008 Share Posted July 11, 2008 j-specs will fall apart quicker if chipped. The turbo spins way faster than a washing machine and you know what happens if you load all your big pants in to a washing machine badly, it bumps across the room and then the bearings fall out. Sadly your turbos will go the same way if you keep running with chipped blades. steel blades last a little longer, but will fall apart quite quickly. Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted July 11, 2008 Author Share Posted July 11, 2008 piccys, sorry about quality Quote Link to comment Share on other sites More sharing options...
JustGav Posted July 11, 2008 Share Posted July 11, 2008 Sorry but that is k-nackered... It will seriously unbalance the turbine which does spin at silly speed. Best case just spat out, worst case engine eats it Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted July 11, 2008 Share Posted July 11, 2008 BAD BAD BAD! As Gav says the turbos spin around/above 100,000 rpm Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted July 11, 2008 Author Share Posted July 11, 2008 b$sta^d :(:(:taped: better look for a new turbo then Quote Link to comment Share on other sites More sharing options...
hadyn Posted July 11, 2008 Share Posted July 11, 2008 Where you getting any symptons? Less boost/poor response anything like that? Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted July 11, 2008 Author Share Posted July 11, 2008 not even fitted it to the car yet, it is for the single conversion that i am doing.... Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 11, 2008 Share Posted July 11, 2008 That's a scrapper, you could get it rebuilt if it's not one of those Ebay things. Probably not worth it though. S/hand turbos are very risky. Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted July 11, 2008 Author Share Posted July 11, 2008 just seen a T04R turbo for sale with the below spec, can you tell me if those are any good, spool fast slow etc.... COMPRESSOR: -Wheel- 64 Trim - 67.0 Inducer / 84.0 Major -Housing- 100 Inlet / 60 Outlet - 0.70 A/R TURBINE: -Wheel- 76 Trim - 73.0 Major / 64.0 Exducer -Housing- T04 inlet / 64.0 outlet - .96 A/R 70mm Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted July 12, 2008 Author Share Posted July 12, 2008 anybody.... Quote Link to comment Share on other sites More sharing options...
JamieP Posted July 12, 2008 Share Posted July 12, 2008 Hks? Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted July 12, 2008 Author Share Posted July 12, 2008 this might sound stupid but am not sure, some one i know just gave me this stats and said look for a turbo close to this as possible and i wont go far wrong. Quote Link to comment Share on other sites More sharing options...
JamieP Posted July 12, 2008 Share Posted July 12, 2008 If its a Hks T04r they are a decent enough turbo, id not buy anything i didn't know who made it. Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted July 12, 2008 Author Share Posted July 12, 2008 no i wont be buying it before i know everything thats why i am asking if those stats are good or not, what is it in those stats that make it fast spooling etc can some one break it down for me. Quote Link to comment Share on other sites More sharing options...
JamieP Posted July 12, 2008 Share Posted July 12, 2008 Some specs here you can compare to. http://www.moreboost.org/turbos.htm Quote Link to comment Share on other sites More sharing options...
123tom123tom Posted July 12, 2008 Author Share Posted July 12, 2008 going by that table which didnt make much sense:) but i managed to pick a few bits out and it says max rwhp 580. Am happy with that but still what is it that indicates how quick it will spool. Any advise there? Quote Link to comment Share on other sites More sharing options...
