miko_supra Posted July 11, 2008 Share Posted July 11, 2008 I removed the stock bov and capped the ends on the manifold as i wanted to check to see if it was leaking (it was.) I was expecting to hear compressor stall, but it just sounded pretty much the same as stock. Which now makes me wonder why if it is a sound suppressing device, that there is hardly any sound to suppress in the first place? Quote Link to comment Share on other sites More sharing options...
jevansio Posted July 11, 2008 Share Posted July 11, 2008 Was this after dumping at full boost Mike? Quote Link to comment Share on other sites More sharing options...
miko_supra Posted July 11, 2008 Author Share Posted July 11, 2008 Yeah I tried it through all the gears. just got a gentle "tss" as i usually do with the stock bov...Makes me wonder if i have another boost leak somewhere Quote Link to comment Share on other sites More sharing options...
jevansio Posted July 11, 2008 Share Posted July 11, 2008 Was out in my mates Cossie the other day, he has an airbox, no BOV, running about 1.8 - 2.0 BAR & he had the propper "budgie" type noise Quote Link to comment Share on other sites More sharing options...
miko_supra Posted July 11, 2008 Author Share Posted July 11, 2008 When i'm near the engine bay and rev the engine on the TB, you can hear a slight bit of compressor stall. Quote Link to comment Share on other sites More sharing options...
jevansio Posted July 11, 2008 Share Posted July 11, 2008 When i'm near the engine bay and rev the engine on the TB, you can hear a slight bit of compressor stall. Maybe drill some holes in the side of the airbox Quote Link to comment Share on other sites More sharing options...
miko_supra Posted July 11, 2008 Author Share Posted July 11, 2008 Maybe drill some holes in the side of the airbox it's worth a shot ... Quote Link to comment Share on other sites More sharing options...
Guest carrotts Posted July 11, 2008 Share Posted July 11, 2008 i get it in my 200sx.. i've got an ssqv qith the adjuster wound all the way in. get the budgie noise at half throttle and the normal TSH at full boost!! Quote Link to comment Share on other sites More sharing options...
miko_supra Posted July 11, 2008 Author Share Posted July 11, 2008 well i'll give it another go when i put my restrictor ring back in as after taking the bov off the boost went from the 16psi i have it set to, to 21psi Quote Link to comment Share on other sites More sharing options...
Lee P Posted July 11, 2008 Share Posted July 11, 2008 You wont hear compressor surge with the stock airbox Quote Link to comment Share on other sites More sharing options...
TurboBrett Posted July 11, 2008 Share Posted July 11, 2008 well i'll give it another go when i put my restrictor ring back in as after taking the bov off the boost went from the 16psi i have it set to, to 21psi if removing your bov gave you an increase in boost (and of 4 pounds) then it is leaking like a b***ch i would put the bov back on but dont plumb up the vacuum line that way its leaking will keep your boost lower enough to do a full boost lift off and wont dump the boost in the process;) then if you still dont get the chuff..chuff..chuff, you know you have 2 leaks:p You wont hear compressor surge with the stock airbox yes you do;), my turbo and intake side is stock, with a k&n panel and the surge is loud even sat in trafic, slightly quieter with the stock filter but still there and the HKS filter is inbetween the 2 volume wise;) Quote Link to comment Share on other sites More sharing options...
TurboBrett Posted July 11, 2008 Share Posted July 11, 2008 i get it in my 200sx.. i've got an ssqv qith the adjuster wound all the way in. get the budgie noise at half throttle and the normal TSH at full boost!! same here;) just not on a 200sx.. the budgie noise.... Vid?? /vbb/images/smilies/bbcode_shock.gif never hear a budgie do that:) Quote Link to comment Share on other sites More sharing options...
miko_supra Posted July 12, 2008 Author Share Posted July 12, 2008 Ok i put my restrictor ring back in now that it's running the higher boost without the bov...I took the front panel of the airbox off and could hear the compressor stall... So this hopefully indicates that there are no more leaks Quote Link to comment Share on other sites More sharing options...
