Has anyone replaced a Heater Matrix on 2001 Seat Alhambra?
Angarak
I think my heater matrix is leaking on my 2001 Seat Alhambra, has anyone here ever tried replacing one and throw any pointers my way.
I've already got the dash out :) ...just cant see how you get the bloody heater system away from the bulkhead so I can remove the matrix :(
No doubt there are some bolts on the bulkhead holding it in place, but short of taking the engine out, I cant see getting access to them being possible without the aid of some umpa-lumpas.
Update:
Well, after ruling out the thermostat, water pump, water pipes, radiator, coolant contamination in the oil (head gasket), the end tank cap ...it wasnt the bloody matrix after all :(
Still, I now know why garages charge so much to replace Matrix's...what a ball ache. Going to spend tomorrow putting all the interior back in.
Fed up with it now so will be taking it to an ex-VW chap in Haydock to see if he can work out why its overheating like a bar steward.
Yes, the OEM water pump uses a plastic impeller which can break off the shaft, I had this problem a while back and changed it with the 'uprated' water pump with brass impeller. I had the pump off a couple days ago to check and it was fine.
I must have overtook a nun in the Supra too fast and she cursed me :(
