JamieP's New Supra Project!
JamieP
  • Replies 2.7k
Posted Images
Yep, cant believe the difference that turbo makes over the smaller non billet version, result. I'll be comparing a couple of the Borg Warner S300 turbos against a T67 billet turbo pretty soon which will be interesting, I've got a feeling the Borg Warner is going to out perform the T67 myself, should know pretty soon. Anyway you've got yourself a great road setup there for sure, nice.
Go on Paul ... next april is still a couple of months to go ... shopping list is still not completed :D:D
Stroker next then :D
Fantastic result.
Be nice but is it worth it? im still on a stock engine and look how close mine is to Pauls fully built and very expensive 3.4, its a lot to spend for a very little bit at the top.
Ive got a good spare engine and after today im thinking just sling that in if mine fails?
Edited by JamieP (see edit history)
http://i30.photobucket.com/albums/c338/jamie450x/paulvjamie.jpg
Surely the bigger CC will give you boost a fair bit lower down the rev range than you are getting just now? You are matching Paul on, what I see as, a far better turbo by the looks of it without having anywhere near the same engine spec.
All depends what you are after, I wouldn't do it because I simply couldn't afford it. It would be a serious consideration if at your level of build and considering a built engine though.
Would be nice to see the spool of that turbo with a 3.4 gassing it.
A nice round 800hp with a neck snapping spool would be the street drivers dream.
Yeah but i dont need it to spool faster, to go 3.4 is going to cost me just over 10grand, im just not sure its worth it.
If your not looking for a faster spool then I wouldn't bother TBH. It doesn't get much better on a stock engine, and as you say it's mental as it is.
Faster spool would be my main reason for doing it. A stroker & slightly higher cams would be insane.
This topic is now closed to further replies.
