JamieP's New Supra Project!
JamieP
  • Replies 2.7k
Posted Images
Nice one Lee, head look spotless:cool:
Ive also purchased one of Chris Wilson's suspension setups, should be with you soon, the RSR's are a bit to hard for my old bones.
Its a very clean engine, no excessive wear and everthing looks great up top.
Really good considering the use the car has had :)
Little update. :)
To give the turbo the clearence needed I had a 10mm spacer welded on to the manifold. This stops the compressor housing touching the number 2 runner.
Also cut the end of the turbo housing off and welded a pipe on the end to give it the turn needed to get down to the intercooler.
The housing is now off to the be polished along with a few other bits.
New CW suspension ready to go on just need some new stock top mounts. :)
