bloody crankseal!!
PhilMorrison
After my engine probs, I thought I was there, but apparently not.
I'm using a GS300 NA crank. I didn't measure the section where the front seal fits, but the rest of it was absolutely untouched flawless. It's all new ACL bearings etc.
It's using a brand new PHR uprated oilpump, and brand new Toyota front crank seal.
The car is only running 1.1bar, and I have a 20mm ID breather per rocker cover.
After only 3 sessions where it's been running perfectly yesterday it started leaking badly from the front crank seal.
I've just pulled the pully and sprocket, and can see the seal. It doesn't appeared to have popped out or anything, so where the hell have I gone wrong?
P.S does anyone have the part number for the front crank seal to hand? I need one by tomorrow :(
Could be a duff pump leaking pressure to the the seal, also check how far the seal is in. If its in past the pump housing it can block the little hole that lets eccess oil flow back to the sump.
I had both these problems, one is easy to fix the other is a PITA.
Hope you get it sorted
Thanks Lee, I'll check to see if it's pushed in to far. I really hope it's the latter..
If I have pushed it in to far, what would be a good method of pulling the seal out without raping it?
I am picking another one up tomorrow morning, but I don't want to kill the seal uncessarily.
You mean turned it over? I know it's non interferance, but didn't want to take the risk. I pressume it's totally fine to do?.
If it helps at all with diagnosis, it doesn't leak immediately. It takes about 30-40 seconds to build up pressure and leak.
Also, I've never done a crank seal before, and recall pushing the seal in until it stopped, so I'm hoping I have just pushed it in to far.. Why doesn't it have a lip or something to stop you being able to do that btw?
Hmmm, I can't even see a drain hole, but I'm doing this on the floor from the bottom, as the ramps tied up..
I've just raped the oil seal out, and other than the damage I did getting it out, it looks as new.
It didn't look massively far in, but I don't know what it should look like.
Like I said, on install I know it was pushed in until it stopped. Is there a correct procedure for installing a crank seal? They come greased IIRC.
This is what I'm looking at with the crank seal removed. Not alot you can tell from a photo, but I was under there, so thought I'd snap it for the sake of it.
http://media.driftworks.com/Phil/Oilpumpseal.jpg
If you have pushed it in too far Phil, it can obscure the drain hole slightly, are you running higher rev limit? and what oil grade?
apart from low visc/ high temps, combined with high RPM, the only other likelihood is the pump is damaged, sorry.
I'm running to 7200rpm which I thought was extremely conservative. I'm really hoping it isn't a damaged pump :(
It's Silkolene Pro S 10w50.
Edited by PhilMorrison (see edit history)
Okay, perhaps a good sign.
I've got a spare block in the workshop, I've just pulled the sprocket on that to see what the crank seal position should look like. It's completely flush with the outer edge of the pump, and I know the crank seal in the engine in the car was pushed in a good 2-3mm further in than that.
So, I'm picking up a new crank seal from Toyota tomorrow at 8:30, and I'll throw it all back together and hopefully make the startline on Saturday morning for round four of the Europeandriftchampionship :D. Wish me luck.
Thanks for your help guys :)
Make this man a mod. :D
Yes, it's supposed to be flush. Best way of putting one in I found was to use a bit of plastic drain pipe from B&Q - one of the standard sizes is just right and you can push it in gently and keep it level. I put some MP grease on the inner edge (the crank edge) and some gasket sealer on the outer edge.
