Brembo calipers
Paul Whiffin
So just to clarify, with the brackets made up from the templates that Kosmic has these would fit with J-Spec disks?
no you are best running with the evo discs as the stud pattern is the same but you will need to make a insert to make up the size in hub
I have these, with UK spec disks and an adaptor. They will NOT fit without a little work, but are a great substitute for the UK calipers as they weight about 75% less than the UK spec calipers, with the same amount of pistons and same disk size. I highly recommend them if you know someone who can machine them to fit.
  • 2 weeks later...
  • 1 month later...
