Ford Escort S1 RST - AWD
Gaz6002
Hi all,
I have a friend who is looking to build a Series 1 Escort RST (mk3 shape) with an AWD system.
Does anyone know where we can find him a Volvo T5 AWD system or another system which will be suitable?
He's already got a couple of Escort donor cars so only need the bits for the bespoke system.
TIA
Getrag use to do a rwd/4wd conversion for the mk3 escort, personly id start with a mk1 and put a cossie engine and 4wd system in it.
Really? Interesting...
He's already got 2 diamond white RSTs to use in the project. He's a bit of a purist but doesn't want to use Cossy stuff as it's so common. He knows exactly what he wants, except the AWD system :D
I'll have a look for the Getrag kit.
A long time ago I had a S2 RST, was a fun car.
I heard about the RWD conversions but the AWD is new to me.
I've seen Cossy running gear under a S1 RST shell but not this kind of conversion. I think that's half the attraction - going into the unknown. He will be using some pretty cool modern parts to get it working.
It's sounding like the Volvo bits are probably the way forward at the mo.
I'll try and keep you all updated.
Guest DIRK DIGGLER
think itwas gartrac rather than getrag...they make gearboxes whereas gartrac have built rally cars for eons....martin scanche or some fella with a funny name used to use a mk3 in karcher colours that was built by gartrac i think in the british rallycross...
as for running gear you could always use an atlas axle for the rear off a 2.8 capri which if built properlyand 5-linked should handle a good 300 horses easy enough..run that through an escort cossie box with a gartrac front end and your sideways before you can say "butter me muffin!"....ahh the old escort days ...it brings back fond memories!!!! im still a crap driver too!!
hope it helps.......
im probably wrong anyhow...
My mate owns a company called SPEC ONE engineering who are cossy specialists.
He has a couple rs500's and a Awd escort rs turbo running escort cosworth running gear.
He has done a few conversions and really knows his fords.
Pm me and can give u his number and he should be able to sort most bits and bobs out for u.
Please don't tell me he's going to butcher two genuine S1 RST's for this?!?!? They must be worth a fair bit now, can't be many left...
I had a hell of a job finding a good one in '96 and gave up and bought a S2 instead.
When I was looking into it, Gartrac did a RWD conversion for the MKIII Escort. Still, could be worth a call.
Saw a MKI Escort once that had a Cossie 4WD floorpan. Stunning car, bet it went well too :D
