Steel pipes?
Axle
If your bpu and buying say an SSQV you dont need to weld the BOV to the pipe, it just gives you the option to use the existing pipes
You could also weld the intake pipe post or pre IC, assuming you have an aftermarket one, blanking off the oem pipes
whats the BOV made off?? your pipe need to be the same, usually an alloy of some type
If you are on about the stock bov its a cast iron
Why does it need to be the same as the BOV, they are normally held together with a clip and seal :search:
Guys im buying a new BOV, but i wasnt sure if i needed a Aluminium flange or a Steel one?
Which metal are the pipes on the supe where the BOV would be placed?
The stock BOV isnt mounted to metal.
If you have aftermarket intercooler pipes they are normally alli as its much lighter than steel.
Cheers lads,
Well im going for this BOV. http://redhat3.admarkonline.com/nippon/product.phtml?p=1057
I have recently bought a Greddy Type R SMIC which directly fits to the original pipes. And as far as im aware no pipes have been changed.
I currently have a BLITZ BOV but i am getting abit of Turbo flutter, so dont think its up to the job really. In anycase i fancy a change :)
Right so, if its the original pipes, should i source a steel flange? Because that BOV is going to need welding on i believe, as its not got a direct flange to fit?
Is there an advantage for all aluminium pipes?
The flanges are normally welded onto the intercooler pipes (aftermarket hardpipes), as you are using the standard plastic pipes, you are not able to do this.
You will need to buy a complete BOV kit specifically for the Supra, these usually fit in the standard BOV location.
