nickball75 Posted July 7, 2008 Share Posted July 7, 2008 may be a daft question but is the sup gonna be drivable if I remove the dash panels? is everything within fixed in place? Im thinking about taking the originals of for spraying but need it for work Link to comment Share on other sites More sharing options...
Supradoopa Posted July 7, 2008 Share Posted July 7, 2008 You can still hook up all the heater controls and odo lights etc just make sure you put the dimmer switch back in or you'll have no indicators. Or is it sidelights one of the two. Link to comment Share on other sites More sharing options...
DannoSupra Posted July 7, 2008 Share Posted July 7, 2008 I drove mine for months with no dash panels. But i had everything off the panels and connected up to the loom still Link to comment Share on other sites More sharing options...
Homer Posted July 7, 2008 Share Posted July 7, 2008 IIRC you can, but need the hazard warning unit in place otherwise the indicators won't work. If driving at night you'll also need the dimmer switch otherwise the instrument cluster won't light. From a safety point of view I'd also fit the heater panel - you don't want the car fogging up! Link to comment Share on other sites More sharing options...
Stratty Posted July 7, 2008 Share Posted July 7, 2008 As Long as everything is plugged back in I dont see why not. I know the airbag light stays on if you dont plug everything back in. I am sure someone will elaborate further. Link to comment Share on other sites More sharing options...
nickball75 Posted July 7, 2008 Author Share Posted July 7, 2008 Brilliant job. I didnt realise there was so much to take off but im guessing its just all plug and play right? Link to comment Share on other sites More sharing options...
DannoSupra Posted July 7, 2008 Share Posted July 7, 2008 As Long as everything is plugged back in I dont see why not. I know the airbag light stays on if you dont plug everything back in. I am sure someone will elaborate further. True... Its the top left cluster with the warning light on... if its comes on, its like a crystal maze game putting the light out Link to comment Share on other sites More sharing options...
supraspeed Posted July 7, 2008 Share Posted July 7, 2008 if u wanted to completely rip out the dash, centre console....everything and make a completely new design would it still be legal- obviously with all switches working Link to comment Share on other sites More sharing options...
bodilx6 Posted July 9, 2008 Share Posted July 9, 2008 You need to keep the top bar with the odometer in place when you have ignition on. Else you will have the airbag light on afterwards with the need to do the difficult fix using TC+AB in the diagnostics port... Link to comment Share on other sites More sharing options...
Jake Posted July 9, 2008 Share Posted July 9, 2008 You need to keep the top bar with the odometer in place when you have ignition on. Else you will have the airbag light on afterwards ...assuming his car has an airbag. Link to comment Share on other sites More sharing options...
jacko Posted August 9, 2008 Share Posted August 9, 2008 i seem to remember my car wouldnt rev properly when the slip control switch was disconnected Link to comment Share on other sites More sharing options...
