Roof Aero Top Screws!!!!!!!!!!!
Guest brko
Guest brko
Hi guys I have a problem with my aerotop m reg, the screws keep coming lose after driving the car. the car hits few bumps and the front screws are lose and the roof then rattles.
what should I do????????
thanks :search:
Hi BRK,
I normally screw in the studs uising the "long" arm of an allen screw hex key and turn "tight" on the short arm into the screw, turning it another half turn approx to get theis degree of tightenting.
If I do not do this, it will slacken off and the roof starts to rattle going over bumps.
Sounds like you need to tighten each screw "fully" after hand-tightening.
Rgds
Geo
thanks guys for reply
I do thighten the screws all the way but I think they are just too old and might need replacing.
Should I buy new ones? How do I fit them????
  • 2 weeks later...
sounds like a common problem ours do this to but only after a while, dont really want to over tighten them case one breaks,ive found if i hand tighten each one then go round again a couple of times then lock down the centre locking bolt seems to work better, i doubt the bolts would be so worn they wouldnt tighten up but depends on how car has been treated previously i guess
  • 9 months later...
