steve spedd Posted July 5, 2008 Share Posted July 5, 2008 I have done a Search and I cant seem to find a guide or anything which lists what each dash light means... I know most of them just one or two im not sure on. Does anyone know of a thread showing the image and what they mean? cheers Link to comment Share on other sites More sharing options...
jevansio Posted July 5, 2008 Share Posted July 5, 2008 (edited) All taken from the owners manual: Red Exclamation In Triangle - Master Warning Light Exclamation In Circle Inside Brackets - Brake System Warning Light Battery Symbol - Discharge Warning Light Engine/Gearbox Symbol - Malfunction Indicator Lamp Oil Can With Drip - Low Oil Pressure Warning Light Oil Can Over Oil - Low Oil Level Warning Light DIFF OIL - Differential Oil Temperature Warning Light ABS - Anti-Lock Brake System Warning Light Car With Door Open - Open Doors Warning Light Car With Rear Light On - Rear Light Failure Warning Light Airbag Deployed - SRS Airbag Warning Light TRC - Traction Control System Indicator / Warning Light TRC OFF - Traction Control System Off Indicator / Warning Light Pipe With Wavey Heat Lines Above - CAT Temperature Warning Light I can summarise the fucntion of each if you like? Edited July 5, 2008 by jevansio (see edit history) Link to comment Share on other sites More sharing options...
miko_supra Posted July 5, 2008 Share Posted July 5, 2008 Not to forget the cat temp warning light too jev Link to comment Share on other sites More sharing options...
jevansio Posted July 5, 2008 Share Posted July 5, 2008 Oh yeah, cheers Mike, my manual doesn't have that symbol in, I guess they realised I'd be going Single Link to comment Share on other sites More sharing options...
steve spedd Posted July 5, 2008 Author Share Posted July 5, 2008 cheers Link to comment Share on other sites More sharing options...
Dazzi Posted July 29, 2008 Share Posted July 29, 2008 hmmm im sure I don't have that many. I know I don't have the traction lights Link to comment Share on other sites More sharing options...
Kaan W Posted July 4, 2012 Share Posted July 4, 2012 (edited) Sorry to bring an old thread up but what lights should be displayed with the key in the on postion without engine started? Also is the low oil level/pressure for the transmission too? Thanks Edited January 5, 2013 by Kaan W (see edit history) Link to comment Share on other sites More sharing options...
Digsy Posted July 4, 2012 Share Posted July 4, 2012 They should all come on (all the ones you have anyway). The "key on" is so you can check the bulbs in the warnng lights. Oil level / pressure is only for the engine. Link to comment Share on other sites More sharing options...
Kaan W Posted July 4, 2012 Share Posted July 4, 2012 They should all come on (all the ones you have anyway). The "key on" is so you can check the bulbs in the warnng lights. Oil level / pressure is only for the engine. Ok thanks. Its just I have my transmission off at the minute so I cant check which lights turn off once started and wondered if the oil level/pressure lights was because theres no transmission fluid. Link to comment Share on other sites More sharing options...
kargato Posted January 3, 2013 Share Posted January 3, 2013 They should all come on (all the ones you have anyway). The "key on" is so you can check the bulbs in the warnng lights. Oil level / pressure is only for the engine. Will the master warning light remain on after the engine is started if any of these warning lights are blown? Link to comment Share on other sites More sharing options...
ashbuster Posted January 3, 2013 Share Posted January 3, 2013 hmm with mine the door and seatbelt light dont show when the key is on, and the abs doesnt either but they all work. when the engine is running the seatbelt and door one works as it should and i know the abs works because i tried it Link to comment Share on other sites More sharing options...
Dnk Posted January 3, 2013 Share Posted January 3, 2013 If the abs light doesn't work i'm pretty sure its a fail on the mot Link to comment Share on other sites More sharing options...
ashbuster Posted January 3, 2013 Share Posted January 3, 2013 ill have to look at the bulb, what about the door and seatbelt one mate because they do work when the engine is running. should it be on without the engine running? im on a facelift dash if that makes a difference Link to comment Share on other sites More sharing options...
Dnk Posted January 3, 2013 Share Posted January 3, 2013 I have no idea on those, isn't there an mot guide on here somewhere, be worth a search or even start an up to date thread on new mot regulations Link to comment Share on other sites More sharing options...
ashbuster Posted January 3, 2013 Share Posted January 3, 2013 ill have to look at the bulb, what about the door and seatbelt one mate because they do work when the engine is running. should it be on without the engine running? im on a facelift dash if that makes a difference ok mate nice one Link to comment Share on other sites More sharing options...
kargato Posted January 4, 2013 Share Posted January 4, 2013 Well my master warning lamp is on constantly, and I have not seen all those lights that were listed by jev. So I was wondering if a blown warning bulb would cause the Master warning to stay on after the engine has been started, and the hand brake has been released, because as we all know, the master lamp stays on with the handbrake, and I think if a door or boot is open as well? Link to comment Share on other sites More sharing options...
ashbuster Posted January 5, 2013 Share Posted January 5, 2013 (edited) yeah thats right mate if the door or boot is open too that light comes on have you checked your brake fluid level? try topping up a little bud Edited January 5, 2013 by ashbuster (see edit history) Link to comment Share on other sites More sharing options...
ashbuster Posted January 5, 2013 Share Posted January 5, 2013 yeah thats right mate if the door or boot is open too that light comes on have you checked your brake fluid level? try topping up a little bud for some reason my abs light is not behaving properly too or maybe it is but facelift is different im not sure but my abs light dont show when i turn the key but as soon as i start the car it shows up then goes out. Link to comment Share on other sites More sharing options...
Benjy Posted January 5, 2013 Share Posted January 5, 2013 If the abs light doesn't work i'm pretty sure its a fail on the mot Bingo Link to comment Share on other sites More sharing options...
ashbuster Posted January 5, 2013 Share Posted January 5, 2013 never mind i just checked again and it does work when you turn the key, it comes on for a couple of seconds then goes out Link to comment Share on other sites More sharing options...
kargato Posted January 6, 2013 Share Posted January 6, 2013 yeah thats right mate if the door or boot is open too that light comes on have you checked your brake fluid level? try topping up a little bud Cool. I sorted all the dash lights that were off, but I also had an underlying fault witht he active spoiler. Disconnecting the ecu sorted my warning lamp issue. Link to comment Share on other sites More sharing options...
