npt and an threads and ptf tape
spiderpigcity
right then guys. i am in the middle of a single conversion and a load of other mods.i have fitted a lot of the boostlogic fittings eg , on the fuel rail, the fuel press reg, the oil drain for the turbo, the oil feed for the turbo. they all use npt or an threads. it says on the instructions that the fittings dont need ptf taoe as they are self sealing. i have mechanic friends who have told me the opposite. i am going to be really pi//ed off if i have to undo all the fuel system and the oil drains and feeds and sensors etc to put ptf tape on them.
can anyone put me straight on this.
thanks
Tapered threads (i.e. NPT) need some form of sealer, either PTFE or preferably something like loctite 577. AN fittings you shouldn't use PTFE on. If it's a male thread going in to a port you need either a Dowty seal (basically a washer with a rubber bit in the middle) or some form of O ring if the port is designed for one. If it's a fitting that goes into another fitting there will be a cone shaped concave bit that the cone on the male fitting fits into. When done up tight these seal.
For example, fuel connections into a pressure reg usually have a O ring. Oil drain from a turbo usually is NPT and needs sealing. Fuel rail fittings normally are designed to seal with a washer.
both of you guys have contradicted each other, whos gonna make it 2 - 1?
No we haven't. Rob said it won't need PTFE "if JIC flare" which is exactly what I just said. The fuel pressure reg gauge is a NPT fitting so will need some form of sealer. We both said exactly the same thing!
