Any electical gurus?
b_have
Something like this will probably be the easiest bet. Has wires going in instead of a moulded cigar lighter plug too, means it will be easy to splice into your cars' wiring. You could design and build your own DC-DC converter, but probably not for a total cost of around a tenner.
Getting a switched feed will be pretty easy. IIRC, the lighter socket is already switched. Just hook into the two wires going to that.
EDIT: This one is a little closer to home!
Edited by Andy Blyth (see edit history)
Many thanks Andy, will the Output of1500mA cause an issue or is that just the max draw? (god I hate being a dunce :()
300mA is fairly low to be honest... an electrical device will only draw as much current as it needs, so in theory even if you strapped 1000A powersupply to it, it would still only draw 300ma (unless you put a metal bar across it, then 1000A suddenly turns it to molten metal :)
Probably a stupid question' date=' but I've seen a few of the cig lighter adapters outputing 7.5V but no mention of the 300mA part. What is contained in the box?[/quote']
300 mA is the current that your camera will draw from a 7.5 V power supply. All you need to do is ensure that your converter can supply at LEAST 300 mA. It's not a problem if it can supply more, even much more. In fact it's better to have some margin to play with.
Re: what's in the box, not a lot to be honest! Probably less than a dozen components, whose purpose is to reduce the (12-14 V) voltage present in your car to the (7.5 V etc.) voltage that your camera needs.
If you do end up using a power supply that can push out a lot more than you need then its best to put a fuse inline. That will save you from having to use heavier cable than you really need. Its good practise to use one anyway to protect the PSU and the wiring.
The problem i found with running camera`s directly off the cars output is interference due to the fluctuation on the alternator, i run mine through a 12/240 unit which is regulated then whatever psu you need to feed the camera/recorder which should also be regulated.
... (unless you put a metal bar across it, then 1000A suddenly turns it to molten metal :)
Yes, I remember hearing a story whereby someone dropped a massive spanner across the terminals of one of the batteries that powers a diesel-electric submarine. There was a big flash..... and they never did find the spanner afterwards.
