how much lucas oil and addative to use?
supra FTW
hi im just about to do my oil chaing on my tt and am going to use lucas 10/40 and the addative that makes the oil better if you no what i mean. it says i ownly put a amount of addative in depending on the amount of oil the car uses i.e if the car takes 5L i use the whole bottle i did a serch but couldnt find how many liters of oil the 2jz takes...any ideas?
many thanks
Matt
i understand silkoline is the bees neez but i thought lucas was a top oil aswel? im not disagreing with you. its hard to describe how it makes the oil better it just does thay have a display that showes how, has anyone ever used lucas and it realy made a mess of your motor?? or is this just all theory im not trying to be argumentative i would just like to no why and for what reson?
its not really the oil mate, its putting in additives, oil companies spend millions to get the 'edge' on the compatition, if this additive is so good how come none of the oil companies add it to their oil? for what its worth the Lucus oil is probably very good (although don't quote me on that)
As long as its a good quality semi or fully synthetic, check the spec for API it should be fine, unless your running a fully built high spec motor, theres a lot of oil snobbery on here;)
I wouldn't use semi-synthetic at all.
Oh dear here we go:rolleyes: there is nothing wrong with semi synthetic, i have run a well modded SR20DET motor on it with no problems at all, and there is nothing wrong with using the best you can find, its just pointless unless you have a highly stressed engine as i said, running over specked oil on the Supra engine is just a waste of money, as its not that special, mechanically speaking.
There's nothing wrong with it no, but personally for the money I don't see why you wouldn't go for a decent fully syn. It is a performance car after all not a family hatchback.
ok i have just finnished the oil chaing with silkoline:innocent:
and that stuffs not cheap lol thanks for pointing me in the right direction.
p.s if thay put the adertive in the oil thay would ownly get to sell you the oil but if sold separatly thay would make two sales ££££;)
many thanks
Matt
[secret ring decoder on]
many thanks
Matt
[/ring decoder off]
So the additive is being sold by a recognized oil company such as Shell, Silkolene...etc?
[/ring decoder off]
the adertive is a lucas adertive, well its gone now so no need to worry about it.
p.p.s my car is compleatly standard so shouldnt need mega race oil should it? just checking for next time.
Look up oilmans threads here mate. Then go to Opie Oils website for the complete breakdown of what you need throughout the car. He, oilman, gives us discount too. :)
