my levoc shifter install
TRACIE_LOU
here are a few pics of how i installed my shifter
first remove trim around gear stick remove ashtray and pull up
push down on the black plast cover at the bottom of gear lever to reveal two screws and remove
now pull gear nob off od wires will be attached
decision time remove wires from od switch or cut i just mine and used connectors supplied
now install alloy bung by screwing it onto shaft you need to set the height so it engages button on lever
now route the cabbles so they dont catch when you change gears install lever onto shaft and secure with three grub screws
re install trim job done
this is how i did it not the difinitive way just a guide
