I'd forgotten just how fanatastic they can be!
Chris Wilson
Had a Supra in the last week that I did a BPU and service on. I took it for a quick test drive and it brought back to me just how great a MKIV is on 16 inch wheels and tyres. ZERO tramlining, excellent power put down on bumps and damp patches, compliant ride. They are so out of favour with the "sheep" that I hadn't driven one in over a year. What a joy!! Now I know why my old MKIV TT used to embarass even exotica in the wet, on track days. She was on 16 inch wheels :)
It does, but it's not too bad so long as you buy proper wheels that have the right offset, the right spigot hole size WITHOUT horrible adaptor rings, and that aren't like boat anchors in weight. Without being rude 90% of people buying wheels don't know what they are doing, and probably a greater percentage selling them :)
Amen brother, I believe :p
As 18 inch tyres go, those mounted on the TTE rims have the edge over most rims, at least the offset, weight and spigot hole size is sensible and correct. If you NEED the brake clearance only an 18 inch rim gives they are a good choice in an off the shelf wheel.
Thank you Mr Wilson. I feel so much better now :)
Personally though, just from the aesthetics point of view, I would struggle to like the look of the car with anything smaller, than say 17's on, but I'm not racing mine (much ;)) :)
:p No idea what your talking about :p
So Chris, if you had a choice between a car on OEM 16s and another on OEM 17s with UK spec brakes (which I believe don't fit under 16s), which would you go for? i.e. better handling with poor brakes, or compromised handling and better brakes.
For a road car I'd have 16 inch rims with decent pads, braided hoses and decent fluid. For a track day car I'd make some custom brakes to go under 17 inch rims, or if budget didn't allow such niceties I'd have UK brakes with race pads under stock UK rims. An out and track car would be on 18 inch rims to get serious brakes in, but would have serious suspension mods, too, but they'd be VERY costly.
I have an idea for a new project for you Chris... it'll look much better than that boxy looking taxi you introduced to the armco ;)
