wastegate/ connection thoughts
123tom123tom
It's been discussed a hundred times mate, there's a massive amount of info here if you search. Myself and others have posted up diagrams and detailed descriptions of the plumbing in the last year or two.
However in short, the side port on the wastegate goes to the compressor housing with a 'T' to the 'In' on the Boost controller, the top port goes to the 'Out' on your boost controller
Are you running a BC, or relying on WG spring?
i will be cartting a electronic controller, also you say a t piece into the compressor housing how is that posible, is it a case of drill and fit, why a t-piece and just not a straight connector
The WG will already have a take off for it, a pipe needs to be plumbed to that to a T piece, with one reference to the the In BC port and one to the compressor housing. Both the BC and WG on the spring side need a pressure reference to balance the boost control with the input from the BC out port. It's the BC that will do the work to balance the two pressures to allow full control of boost. Without either the WG cannot be controlled beyond the pressure the spring is set at (either that or it will not be able to keep it steady).
Edit - There was quite a good video posted earlier today: http://www.mkivsupra.net/vbb/showthread.php?t=155401 It doesn't explain it all, but it's a start ;)
Also: http://www.howstuffworks.com/turbo.htm :)
cheers mate, glad your hear :) i would be knackered. found the diagram on this as well, what i meant by drilling was the compressor housing and then thread some kind of nipple or is it done some other way
yeah already seen them, just couldnt get my head round how it is plumbed in
BTW, check the post again as I added some useful links
Which turbo do you have? Nearly all ones designed for petrol use have the port pre-drilled and the flange fitted. If you don't have one, then you'll need to:
1) review which turbo you have bought!
2) remove the compressor housing and drill/tap a thread into it just after the exit from the compressor blades
