does anyone actually own a perfect working single car?
supra dan
  • Replies 81
so why is it more maintenance? this was my earlier point most people seem to be forever fixing singles. i would prefer to drive it than keep fixing it. i still dont see why you cant fit good quality parts, get it mapped then just drive it.
It's the little things, FMS's seem to be a common problem, misfires too. As Paul says, it's not the stuff you replace, it's the stuff you don't that is now 10+ years old and under a lot more strain than it was originally intended.
Take mine for example, recently I've had:
1) Clutch release fork bolts shear (rendered clutch useless), probably wouldn't have happened in a stock car with stock clutch
2) Another missfire. Coilpack connectors are all brand new & hasn't had a miss in ages yet developed this. Turned out the pins in the coilpacks weren't making a good contact.
3) Exahust manifold blowing around gasket. Been fine for over a year that, probably due to the immense stress it undergoes.
These are just a small example, & each of the parts that I used in those areas was top quality (RPS Stage 3 clutch & RPS Segmented Flywheel, new coilpacks & connectors, Sound Performance manifold - I didn't scrimp when buying any of that kit).
i would say my car is pretty damm reliable (famous last words) but it took time to get there, you have to remember you are performing some pretty major surgery when going single, there is an inevitable period after fittment where things need checking etc before you can call the install a success, think how much R and D Mr T put into the original twin turbo design and how much testing was done, then think how much R and D went into all your aftermarket components (probably not very much) you then have to realise you are putting a lot more strain on virtually every other component on the car (not just engine), you can not close the bonnet on a single install and re-open it in 10k mile for the oil change
spot on
good post, thanks. i am beginning to see the pitfalls. seems as though there is some luck involved aswell, some seem to have more problems than others.
wise words indeed
