Ewen Posted June 28, 2008 Share Posted June 28, 2008 (edited) ....I'd like to mount the controller somewhere that doesn't mean drilling holes in the dash or glove box, or have cables in plain sight...anyone care to share what they have done ? Also, has anyone got any pics of Defi BF gauges mounted on the A pillar but using the brackets supplied (not using an actual pillar pod) ? Edited June 28, 2008 by Ewen (see edit history) Link to comment Share on other sites More sharing options...
heckler Posted June 28, 2008 Share Posted June 28, 2008 my controller is velcroed between the drivers seat and gearbox tunnel, all the cables are hidden/stuffed in the cover over the gearbox/dash Link to comment Share on other sites More sharing options...
Shilakadaddy Posted June 28, 2008 Share Posted June 28, 2008 You could mount it in the glove box without having to drill any holes. Theres a plastic panel in the top of the glove box that can be removed, or there's the glove box light which is also in the top that could be removed allowing space for wires. Link to comment Share on other sites More sharing options...
Nic Posted June 28, 2008 Share Posted June 28, 2008 My controller is mounted underneath the steering column with doubles side foam tape. Link to comment Share on other sites More sharing options...
Ewen Posted June 28, 2008 Author Share Posted June 28, 2008 Many thanks Link to comment Share on other sites More sharing options...
Pixelfill Posted June 28, 2008 Share Posted June 28, 2008 (edited) mine is in the cubby hole under the stereo surrounded by photographic flight case packing foam. I'll see if I've a picture anywhere. Edit: pic from before I fitted the packing foam Mike Edited June 28, 2008 by Pixelfill (see edit history) Link to comment Share on other sites More sharing options...
