what is the sensor that goes into the cat
Guest toyokid
Guest toyokid
hi i have a 1994 n/a jspec manual would like to know what is the sensor that goes into the cat.is it needed.i take it the other two sensors on the down pipes are the o2 sensors
Guest toyokid
yeah two o2 sensors and one cat temp sensor (you get a warning light on the dash if a temp limit is exceeded)
what could happen if it doesnt work
the manifold i bought only had a boss to fit just 1 lamba i got another boss fitted to the other side of the manifold as the stock in does and run it with both but the company i imported it from try to advise me to run it with 1 and to just solder another wire tapped into that sensor to run both sensor ports from 1 sensor i thought they where full of it and got another boss made but would it of been alright
