advice3.0 na ,turbo convertion with twin turbo 2jzgte
Guest justintime
Guest justintime
ok i have a 93 3.0 auto na
i am looking at a set of twin turbos with manifold from a 2jz gte
can you advise me on if this a suitable convertion
i have been advised that having a convertion from na/to turbo would be ok as long as i keep the boost low.
what do you think is this correct all replies welcome.
Guest justintime
1. Have a capital.
2. Have a full stop.
It won't work as the na head is different to the tt head.
If you want a decent reply, we would like a decent post.
Shame that your so harsh.!
However your reply is noted! thank you.
Oh well :)
The 2jz-ge head has different port positions and as such the 2jz-gte manifold does not line up on it correct (it is a good bit off, so it isn't a case of boring out a bit). Simply sticking a set of turbo's on and running low boost will result in a very expensive repair bill. There is a lot more to putting forced induction on a car than simply strapping a turbo to the block.
Guest justintime
Oh well :)
Thanks for that i see what you are saying and understand, thats the advice i required so i wont be going down that route then.!
