Japshow- My son came 1st place Class C
AshBhp
Well done Ash and Yasir :thumbs:
It's really good to see an 'amateur' beat all these pro garages (which normally decimate the competition).
Watched him run a couple of times, the car was really struggling for track off the line, but was like a rocket once it hooked up, there's clearly a lot more to come!
  • Replies 51
http://www.japshow.co.uk/r_jap2008.php
Class C – Honda/Acura
Yasir Dar
Civic
12.6079 @ 122.14 FWD Street tyres http://uk.youtube.com/watch?v=6mGCC-uqQ90
http://img.photobucket.com/albums/v20/ashbhp/civic/Japshow08.jpg
My Son, Yasir started his Civic Turbo project last year at the age of 19.
Japshow was his first proper testing at 12psi, so more to come:d
He has done all the chassis, engine build and mapping by himself.
Well done Son. :trophy:
Here the spec-
B18a block
Darton sleeved
Wiseco pistons
Eagle H-beam ESP rods
ARP head & rod bolts
B18c head
Mild port & polish
5-angle valve job
Crower springs & retainers
Crower stage 2 turbo cams
Skunk2 pro-series cam gears
Supertech bronze valve guides
Edelbroc victor-x intake manifold
Edelbroc mustang 70mm throttle body
Custom top mount manifold
Garret GT35R turbo with precision intake housing
Tial 44m wastegate
PWR 750hp intercooler
Stock S9B gearbox
Competion clutch stage 4 6-puck spring clutch
Gator shafts
Hasport mounts
SPfab traction bar
K-sport coilovers
Hondata S300 ecu
RC 750cc injectors
GM 3-bar map sensor
Bosch fuel pump
Custom fuel lines
This was our first start vid
http://img.photobucket.com/albums/v20/ashbhp/civic/th_08032008.jpg
rinsin'
good vid and awesome spec ..good time for not alot of boost...how much can you push on the B18? alot more?
Thanks
A stock B18 is good for 300fwhp at 10psi max
We built our block for 800whp :D
Yasir aiming for a solid 500whp for now, his aim is 10 sec quarter for FWD.
christ can take a bit of a canning then!
sounds mint...have respect for him, as thats what were trying to do, accpet were not going to get 500whp...:(...relying on power to weight :cool: :lol:
I wish him luck,. in the up and coming events!
  • 1 month later...
