jassi_hayre Posted June 25, 2008 Share Posted June 25, 2008 Hi all This has been happening intermitently over the last two weeks. Basically started with the rev counter getting stuck at around 2000 rpm. Would not go up or down. Then the speedo started sticking at around 40mph. Now the speedo is dead most of the time and the rev counter works intermitently. Car is a 95 Jspec NA. Most of the probs with dead speedo point to kph to mph converter problems but my rev counter is also playing up. Can you suggest what to check. Thanks Jas Quote Link to comment Share on other sites More sharing options...
jassi_hayre Posted June 29, 2008 Author Share Posted June 29, 2008 Changed the kph to mph converter which has fixed the speedo but the rev counter is still sticking usually at 1800 revs. Incidentally since changing the converter the car seems to be running faster and smoother for some reason (not changed anything else). Jas Quote Link to comment Share on other sites More sharing options...
