daz Posted June 25, 2008 Share Posted June 25, 2008 put me heater on hot but it came out cold any ideas what look at first cheers daz Quote Link to comment Share on other sites More sharing options...
SteveR Posted June 25, 2008 Share Posted June 25, 2008 Coolant level in the overflow tank/air locks in the coolant system; at the back of the engine bay where 2 pipes head through the bulkhead (and on to the heater matrix). Quote Link to comment Share on other sites More sharing options...
daz Posted June 25, 2008 Author Share Posted June 25, 2008 thanks bud i will have look later cheers daz Quote Link to comment Share on other sites More sharing options...
SteveR Posted June 25, 2008 Share Posted June 25, 2008 Drive it round for 20~30 mins so it's fully up to temp, turn the heater dial to full hot & stick the fans on, if possible park facing UP a VERY steep hill and with the engine running squish all the pipes you can get to. Quote Link to comment Share on other sites More sharing options...
Havard Posted June 25, 2008 Share Posted June 25, 2008 I would split the pipe at the highest point on the system and see if there is any coolant in there. I did a mod on my pipework so that I can top up the system from the rear of the engine and I have never had any problems since..!! H. Quote Link to comment Share on other sites More sharing options...
daz Posted June 25, 2008 Author Share Posted June 25, 2008 hot heat now all the pipes was hot but the back pipe was cold near bulk head took it off and rad cap aswell blown down the pipe coolant came out the rad put all back put the heater on ten min later hot air must off been air lock . cheers steveR Quote Link to comment Share on other sites More sharing options...
SteveR Posted June 26, 2008 Share Posted June 26, 2008 Glad it's sorted. Reading the above, I should have warned you NOT to open the cooling system (rad cap/remove a hose) when the car is hot, as it's under pressure and you can get very badly burned if boiling hot coolant comes flooding out! You've got it sorted though, and no harm done - but anyone else reading this please beware. Daz keep an eye on the coolant expansion bottle, you may need to top it up now you've removed some air from the system. There are little marks on the side of the bottle telling you where the level should be. Quote Link to comment Share on other sites More sharing options...
