Jim_1979 Posted June 23, 2008 Share Posted June 23, 2008 I have a Blitz Super Sound DD Bov from my old mr2. It had no fitment on it as the old one stayed with the mr2. I bought an adapter from Zena racing in hong kong. The adapter hose size is 34mm which is obviously quite bigger compared with the standard hose size. Is there anyway This can be fitted? Can you get a hose which goes from the Supra size to 34mm?? I suppose I could simply get it welded on to my FMIC piping. But if I could get it fitted using hoses etc, I'd prefer. cheers! Quote Link to comment Share on other sites More sharing options...
Jim_1979 Posted June 24, 2008 Author Share Posted June 24, 2008 bump Quote Link to comment Share on other sites More sharing options...
Pabs Posted June 24, 2008 Share Posted June 24, 2008 you're not really doing something that is common to the supra, so you won't find a pipe specifically listed for this purpose - but I'm sure you'll be able to find some generic hosing that'll do the job, be it Samco, SFS or similar? Personally I wouldn't do it tho - either go for the hardpipe weld, or just get a BOV/adapter that is specific to the supra Quote Link to comment Share on other sites More sharing options...
Jim_1979 Posted June 24, 2008 Author Share Posted June 24, 2008 I couldn't find any adapter for the Blitz BOV apart from this one. I think I'll just get it welded onto my FMIC piping. Question.... When welded onto the FMIC piping at the rhs near the battery, where does the vac line run from the bov? If it was fitted in stock location, it would obviously use the same hose as the stock bov vac line. But when it's at the other side of the engine, I just don't know. Any ideas? Quote Link to comment Share on other sites More sharing options...
