600+bhp S13 for £30.
Guest Richie
This is your chance to own the ND Developed 600+bhp 1.8l S13 for only £30. I have owned this car for over 2 years now and am at a point where I have no other option than to sell my pride and joy due to unforeseen circumstances.
This car has had over £75,000 spent on it to bring it up to its present condition. If you do not know about this car you can see some onboard footage with this months Redline magazine (200mph Challenge). This car has also been featured many times in national media. I will be selling 800 Tickets at £30 each and the draw will not take place until all tickets have sold. That’s pretty good odd if you ask me. This will cover the original sum I advertised the car for. An individual can by as many tickets as they want and the draw will be officially held with witnesses. Those who enter would get a signed form sent explaining the rules which they would then sign and return with a cheque. Once all funds have cleared the draw will take place at an agreed venue by an agreed person to ensure fairness. See link below for onboard run at santa pod
http://mysite.wanadoo-members.co.uk...1.6_sec_Pod.wmv
If you want to buy tickets e-mail [email protected] and please include the following details: -
Your Full name
Address
Age (no Under 17's)
SPEC LIST
0-60mph 3.56sec
0-100mph 7.419sec
60-100mph 4.07sec
Engine Mods:-
CA18DET 1809cc Turbo
9000Rpm Rev Limit
Best Top Speed So Far 186Mph @1.25mile
ND Forged Low Comp Pistons
ND Chrome Piston Rings
Lightened & Balanced Bottom End
ND Prototype Flywheel & Clutch
ND Steel Billet Crankshaft
Trust Steel Conrods
ND Lightweight Solid Lifters
Tomei 260 Solid Profile Camshafts (Currently HKS 264 cams)
Tomei Wide Coil Valve Springs
Tomei Adjustable Cam Pulleys
ND Race Spec Cylinder Head (GT Combustion Chambers)
ND 1000cc Fuel Injectors
Full Dash 8 Fuel Lines
ND Large Bore Alloy Fuel Rail
ND Prototype large bore throttle
Modified throttle pedal
ND TPS
ND Prototype inlet Manifold (3" Inlet)
ND Prototype plenum
SARD Adjustable Fuel Pressure Regulator
Bosch Motorsport Gp B Fuel Pump
Motec M4 Pro Ecu
Motec Launch Control
ND Full Engine Management System Loom
Bosch Idle Control Valve
Full Greddy Turbine Kit TD06-25G
Modified Low lag 25G turbo 360* oversize thrust bearing
Greddy external wastegate
ND Prototype Rad
Stant High Px rad cap
Mocal oil cooler system
Remote filter housing
ND Prototype Front Mounted Intercooler
NX N-Tercooler
3" Intercooler Pipework
Samco Blue Hoses
Cusco Catch Tank
ND Breather System inc Sump Return
8.0 To 1 Compression Ratio
AEM CDI
ND Coil pack
HKS 40i Plugs
K1 Racing Leads
Apexi Filter
4" Alloy Filter adaptor
HKS Super Dragger Full Exhaust System
3" Turbo back exhaust
3 Bar Map Sensor
Nismo oil filler cap
Remote Mounted Battery
Alloy Battery Cover
ND rocker cover
Polished cam cover
Polished PAS tank
Transmission:-
OS Giken Long Ratio Gearkit
OS Giken 600bhp+ Mainshaft
S14 rear housing
ND Twin Plate Clutch Assembly
ND Quickshift Kit
Interior Mods:-
Greddy 60mm EGT
ND Boost Gauge Kit
ND Oil Pressure Gauge
ND Oil Temp Gauge
RB Alloy gauge mounting plate
Weber Alpha Lambda Monitor
Greddy B Spec Boost Controller 2.5 BAR
Greddy Turbo Timer
Sparco Bucket Seats
Nismo gear knob
Momo millenium steering wheel
Momo boss
Nismo Key
Luke 3" Harnesses
Stripped rear chassis
Chassis Mods:-
Leda 2.5" Race Coilover Suspension Kit
Nismo Rear Sub-Frame Bushes (X 4)
Lowered 80mm All Round
Whiteline Front anti roll bar
Solid Steering Bush
Lightened to 1100kg
Brake Mods:-
ND 355mm Front Brake Kit
Goodridge Braided Hoses
Mintex Synthetic Brake Fluid
Mintex F4R Front Pads
DS2500
ABS Removed
Wheel Mods:-
18" X 8" Khan RSR's x4
Dunlop D01J 235/40/18 Tyres for racing
18"x 7.5" Khan RSR's x4
Avon ZZ1 225/40/18 for road use
15" X 10"Compomotive MO's
BF Drag Radials 26" X 10.5"
Ice:-
Clifford 600 Alarm
All Ice removed
Exterior:-
Jun front bumper
Jun side skirts
Eiribuni rear wing
Jun rear 3/4 panels
Various decals
Personalized plate
Stats:
BHP 532.6@hubs @28psi
Torque 484lb/ft
0-60 3.56sec
Qtr Mile 11.4@ 129mph +7 IGN ADV
Top Speed 207mph @9000rpm
"I will be selling 800 Tickets at £30 each and the draw will not take place until all tickets have sold. That’s pretty good odd if you ask me."
Yup sounds great to me....... uhm, so if you don't sell all the tickets there will be no draw? :baa:
Rico try this link mate.
http://mysite.wanadoo-members.co.uk/rjtuning/Onboard_11.6_sec_Pod.wmv
As I'm sure some of you can appreciate valuing a car like this is somewhat difficult. Getting this sort of power out of 1.8l CA18DET has never been done before so the development and costs involved are not your typical bolt on mod route as can be seen from the spec list as the car stands now.
Here is an update including entry form
I have looked into all the legal implications already and you need not worry. This is not a lottery as it has an element of skill involed in answering the following very difficult question, which you will have explained to you when i e-mail everyone at the weekend.
"What colour is the white car I am raffling?".
All foreigners can enter but you will have to collect the car.
I will also provide free of charge a full track day to the winner so that they have the opportunity to learn a few things about the car.
Raffle Form.doc
Elliot £10, come on mate I know I'm cheap but that's a bit low. How's about £15 ;) . Dude its hard enough getting peolple to spend £30 never mind 1K
Seen this on the 200 owners club site. Way back when I was 19 this car made me want an s13, it was only 400bhp back then. It is an awesome car, but could have had same power for less $$ if they had put the SR20 engine in or even a RB25. Your not gonna miss 30 quid and 800 to 1 are decent odds providing they all sell. I'll be buying one and i'll see if I can sell a few others. :) Even if you dont want the car, if you win you could try and sell it back to Richie for 10K, that way he's got 14K to spend on his wedding and he's still got his car. And you've got 10K to put towards whatever, win-win. :)
