supra FTW Posted June 22, 2008 Share Posted June 22, 2008 hi all i have just bought my first import supra tt and it has a missfire. at first it was when the second turbo comes in and it misfired breifly a couple of times but still went to the red line but now it does that in the first gears but 3rd 4th an so on it does it but does it bad at 5k and wont go any futher in the revs:( how do i check my ignition system? many thanks Matt Quote Link to comment Share on other sites More sharing options...
Nic Posted June 23, 2008 Share Posted June 23, 2008 (edited) Check the plugs and the connectors to the coil packs (these sit on top of the plugs), these are usual cause of misfire at higher boost. Have read of these threads in the FAQ section http://mkivsupra.net/vbb/showthread.php?t=41927 http://mkivsupra.net/vbb/showthread.php?t=61141 http://mkivsupra.net/vbb/showthread.php?t=35931 Edited June 23, 2008 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
supra FTW Posted June 23, 2008 Author Share Posted June 23, 2008 thank you i will have a good check of the coil packs and connectors tomorow once i have chainged my plugs. Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted June 24, 2008 Share Posted June 24, 2008 thank you i will have a good check of the coil packs and connectors tomorow once i have chainged my plugs. i had the same problem and it was my plugs Quote Link to comment Share on other sites More sharing options...
supra FTW Posted June 26, 2008 Author Share Posted June 26, 2008 i have alredy orderd a full set of irodium tip plugs,its got platunum onse in now but thay look old. so once there in if that doesnt do it then i will check the conections to the coil packs as i noticed mine are missing the white plastic bit that holds the prongs in place so its dificult to plug them in:rolleyes: then the coil packs, is there any way to check a coil pack?... or do i just have to buy all new ones? regardes Matt Quote Link to comment Share on other sites More sharing options...
supra FTW Posted June 27, 2008 Author Share Posted June 27, 2008 missfire fixed with my new plugs:d however my conections to the coil packs are fu*kd lol no white bit between the prongs and it broke down on the way home after doing the plugs and i kind fixed it enough to get home then had to slide the black plastic gard up the wires put the conections on individualy to enshure a good contact then wiggle the black plastic bit back down so it wouldnt arc across. now its all fixed and running amazingly smoooth. where can i get new connectors? the ones to the coilpack? many thanks Matt Quote Link to comment Share on other sites More sharing options...
Nic Posted June 27, 2008 Share Posted June 27, 2008 See FAQ section here, your local Toyota dealer should be able to supply, part number 90980-11246 http://mkivsupra.net/vbb/showthread.php?t=61141 Quote Link to comment Share on other sites More sharing options...
supra FTW Posted June 27, 2008 Author Share Posted June 27, 2008 See FAQ section here, your local Toyota dealer should be able to supply, part number 90980-11246 http://mkivsupra.net/vbb/showthread.php?t=61141 thanks mate youve been a big help:) Quote Link to comment Share on other sites More sharing options...
