bmx1lew Posted June 22, 2008 Share Posted June 22, 2008 Has or Could any one take pics of how they Installed there Greddy Profec B II Boost controller or any similar boost controllers. Im a little unsure where to mount the solenoid. If any one can give me tips or instruction on how to do this I would greatly appreciate it, The wiring parts I can do, Just a little unsure about the pipe and solenoid bit. I bought the Boost controller second hand so I need a few little bits for it. Looks Like I need 4mm hose and 6mm, A filter, do I need the screw and rubber washers? and do I need the 3 way part? Lew. Link to comment Share on other sites More sharing options...
Guest Nizam Posted June 22, 2008 Share Posted June 22, 2008 why do you need it mate? Link to comment Share on other sites More sharing options...
bmx1lew Posted June 22, 2008 Author Share Posted June 22, 2008 because you cant run a boost gauge without pipes vacume pipes. Link to comment Share on other sites More sharing options...
hodge Posted June 22, 2008 Share Posted June 22, 2008 tried phoning ya mate but no answer giz a ring and ill point you in the right direction. Link to comment Share on other sites More sharing options...
swandip Posted June 22, 2008 Share Posted June 22, 2008 I also have one of these controllers and done lots of searching but can anyone tell me the best settings for this type of boost gadge on a Jspec TT BPU for both the high and Lo. Link to comment Share on other sites More sharing options...
Guest Nizam Posted June 22, 2008 Share Posted June 22, 2008 what the diffrent your one and my blitz boost controller mate? Link to comment Share on other sites More sharing options...
letmeshowyou Posted June 22, 2008 Share Posted June 22, 2008 what car did this come off of? One of the ports will need to swapped over on the solenoid if it's going on a supra with the twins still installed Link to comment Share on other sites More sharing options...
Jamesy W Posted June 22, 2008 Share Posted June 22, 2008 Dude http://www.mkivsupra.net/vbb/showthread.php?t=154442 Link to comment Share on other sites More sharing options...
letmeshowyou Posted June 22, 2008 Share Posted June 22, 2008 Ah. I just read that, and hadn't noticed it was the same person Link to comment Share on other sites More sharing options...
AndrewOW Posted June 22, 2008 Share Posted June 22, 2008 R.i.p. Link to comment Share on other sites More sharing options...
