Hi Stall Torque Converter/cooler £280
absz
  • 1 month later...
  • 4 weeks later...
  • 1 month later...
As previously mentioned......Pics and spec!
Then you might get some takers:blink:
what else do you want to know? its a TC like a picture is going to help and its stall rate is 3800, you can have 60bhp or 600bhp that does not effect how this is used or what the specs are.
Please can we know how many rows the cooler has?
What size is it?
Where is it supposed to mount?
Does it come with pipes and fittings?
Mounting brackets?
TC..
What HP was it built to take?
What make is it?
My std TC slips continually @ anything above 500hp on a single turbo.
The oil cooler is no longer available hence the price reduction and edit.
High stall is made by precision. 3800 stall, its pink in colour will get a picture up tonite:) the unit is not modified in any way. don't know what power rating these things are made for ?
and what are the advantages for say a BPU car?
Quicker shifts etc?
a 3700 rpm stall on a bpu would be complete overkill, the high stall allows you to get the car in the power band for faster launchs and also when enduldging in some spirited overtaking, it has nothing to do with shift speed that is dictated by the auto box
I like overkill :eyebrows:
Remember the transmission coolers to go with it though. I'm running 3 after managing to break a BL box when I just had 1.
Cheers,
Brian.
