Thor Delimiter
jimmy_supra
well mine's standard but have had a alot more than 112 out of it:innocent:
edit...thinking about it are Uk specs allready delimited? or do they have a higher limit set?
UK spec Supra iirc have a limit of 155mph (using stock ecu) however you will get people that have had more but unknown if this is speedo speed or GPS.
It was only J-Spec Supras that had the 112mph limiter on them.
Thanks for clearing that up, so thats where i got the 155mph from. So 155mph is the fastest mine could go before upgrading the ECU?
Yes, unless the Thor delimiter works on a UK spec, however unless you are going to i.e TOTB to do high speed runs or frequent track days with straights long enough is 155mph not more than enough? ;)
Yeah 155 is fast enough but would be nice to know that i could go faster:) Next question:) Has anybody ever tried it on a UK spec? Also what does it take the J-Spec supes up to, 180?
