pablo1971 Posted June 18, 2008 Share Posted June 18, 2008 ello peeps just got my dials today (thanks steveo) just wondered where's the best place to mount the dimmer control was. i was gonna put it under the steering collumn any advise would be great Quote Link to comment Share on other sites More sharing options...
Bryan_Jones Posted June 18, 2008 Share Posted June 18, 2008 I'd be more concerned with actually getting the dials on without removing the needles. :( I've had a go at fitting them with no joy. http://www.mkivsupra.net/vbb/showthread.php?t=138834&page=21 See if you have any better ideas. Quote Link to comment Share on other sites More sharing options...
pablo1971 Posted June 18, 2008 Author Share Posted June 18, 2008 I'd be more concerned with actually getting the dials on without removing the needles. :( I've had a go at fitting them with no joy. http://www.mkivsupra.net/vbb/showthread.php?t=138834&page=21 See if you have any better ideas. fitted em no worrys matey. they just slip over the needles, you have to push the dial right under the black needle support thingy to get them over the other side of the needle, hope this is of some help Quote Link to comment Share on other sites More sharing options...
Dazzi Posted June 18, 2008 Share Posted June 18, 2008 You could take the dimmer out of its casing and place it where the oem one is? I haven't had a go of mine yet. Quote Link to comment Share on other sites More sharing options...
pablo1971 Posted June 18, 2008 Author Share Posted June 18, 2008 You could take the dimmer out of its casing and place it where the oem one is? I haven't had a go of mine yet. i thought because the new dimmer has a switch on it aswell it wouldn't fit there, might give it a try Quote Link to comment Share on other sites More sharing options...
Dazzi Posted June 18, 2008 Share Posted June 18, 2008 i thought because the new dimmer has a switch on it aswell it wouldn't fit there, might give it a try Take out the casing and took away? Im not having green so the switch will be left on blue and tucked away - will have to see if it works in the oem dimmer slot tonight. Quote Link to comment Share on other sites More sharing options...
pablo1971 Posted June 18, 2008 Author Share Posted June 18, 2008 Take out the casing and took away? Im not having green so the switch will be left on blue and tucked away - will have to see if it works in the oem dimmer slot tonight. might leave the casing on as not to big and still took it away behind the dash somewhere. thinking blue glow is the way to go anyway Quote Link to comment Share on other sites More sharing options...
liam1 Posted June 18, 2008 Share Posted June 18, 2008 (edited) here's pic of where mine is mounted just below steering wheel it doesnt get in the way when you get in and out and really handy when you want to adjust/switch between colours, Edited June 18, 2008 by liam1 spelling error (see edit history) Quote Link to comment Share on other sites More sharing options...
pablo1971 Posted June 18, 2008 Author Share Posted June 18, 2008 (edited) here's pic of where mine is mounted just below steering wheel it doesnt get in the way when you get in and out and really handy when you want to adjust/switch between colours, http://i172.photobucket.com/albums/w21/woolm1000/101_0117.jpg did u just screw it to the underneath of the steering column? cant really see on the pic. nice dash btw Edited June 18, 2008 by pablo1971 (see edit history) Quote Link to comment Share on other sites More sharing options...
liam1 Posted June 18, 2008 Share Posted June 18, 2008 aye mate thanks for comment on dash. Quote Link to comment Share on other sites More sharing options...
pablo1971 Posted June 18, 2008 Author Share Posted June 18, 2008 aye mate thanks for comment on dash. no worrys matey. i like to see a well sprayed dash. gonna flush mount the switch on the panal below steering column now as will be less on show i thinks Quote Link to comment Share on other sites More sharing options...
Bryan_Jones Posted June 20, 2008 Share Posted June 20, 2008 fitted em no worrys matey. they just slip over the needles, you have to push the dial right under the black needle support thingy to get them over the other side of the needle, hope this is of some help Yeah I managed it. Just a little worried about bending it. Got mine all fitted now. Quote Link to comment Share on other sites More sharing options...
supra steveo Posted June 20, 2008 Share Posted June 20, 2008 every one happy ? i would of just stuck it down by behind the dash next to the ignition Quote Link to comment Share on other sites More sharing options...
_Shane_ Posted June 20, 2008 Share Posted June 20, 2008 my needles popped off speedo is 15mph out now Quote Link to comment Share on other sites More sharing options...
Dazzi Posted June 20, 2008 Share Posted June 20, 2008 my needles popped off speedo is 15mph out now Private land and a satnav I suggest Quote Link to comment Share on other sites More sharing options...
_Shane_ Posted June 20, 2008 Share Posted June 20, 2008 but you cant adjust the needles while the car is running even with the plastic face off as it will just go back to the previous position Will go at it again tomor Quote Link to comment Share on other sites More sharing options...
