kieren1234 Posted June 18, 2008 Share Posted June 18, 2008 Hi guys, i have a slight problem with the supra. Everytime i go over a bump/put full lock on or brake when going forward or reversing, my front right hand side of the car makes a loud knock noise. I took the car to Motosave as it is local and they said it was the track rod end that was loose. I bought a brand new one and had it fitted by them but I still have the same problem. Does anyone know what it could be, i will take it to a garage soon but would be nice to know what it could be. Many thanks. Quote Link to comment Share on other sites More sharing options...
Nic Posted June 18, 2008 Share Posted June 18, 2008 Usually a sign of loose sub frame bolts, also make sure all the bolts that hold the suspension arms are tight. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted June 18, 2008 Share Posted June 18, 2008 Could be a ball joint? Quote Link to comment Share on other sites More sharing options...
supra matt Posted June 18, 2008 Share Posted June 18, 2008 sounds like top mount to me mate Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted June 18, 2008 Author Share Posted June 18, 2008 Thanks for the sugestions guys. Hopefully its nothing too serious (expensive). I will get it looked at and booked in somewhere. Quote Link to comment Share on other sites More sharing options...
gregd125 Posted June 18, 2008 Share Posted June 18, 2008 Mine was doing that, and the subframe bolts were loose by half a turn. Got them tightened and that sorted it for a while, and then the noise returned. On inspection, my mechanic found that the passenger side lower engine mount was knackered. I'm trying to find one at the moment, and not having any luck. Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted June 19, 2008 Author Share Posted June 19, 2008 Will bear it in mind. Just need a chance to get it looked at when im not working! Quote Link to comment Share on other sites More sharing options...
