Jellybean Posted June 18, 2008 Share Posted June 18, 2008 anybody have this fitted, any performance increase/ decrease or some nice additoional noise Link to comment Share on other sites More sharing options...
steb9780 Posted June 18, 2008 Share Posted June 18, 2008 Supposed to be one of the better aftermarket kits from what I have read, due to it having it's own cooling box. Link to comment Share on other sites More sharing options...
bolarbag Posted June 18, 2008 Share Posted June 18, 2008 Supposed to be one of the better aftermarket kits from what I have read, due to it having it's own cooling box. Sounds very much like stock then - Toyota call it an airbox:rolleyes: Its purely bling factor Link to comment Share on other sites More sharing options...
Gaz6002 Posted June 18, 2008 Share Posted June 18, 2008 Its purely bling factor Depends if you can fit the OEM box to your setup really. I'd like to see one of these for myself TBH, I've got a lot of questions that need answering. The main one being will this box flow enough air to keep a single turbo happy at high boost? Link to comment Share on other sites More sharing options...
bolarbag Posted June 18, 2008 Share Posted June 18, 2008 anybody have this fitted, any performance increase/ decrease or some nice additoional noise I assumed you were bpu If the filter is not of paper origin then any aftermarket filter with a decent filter element(not HKS) and a heat sheild will do the same job If your turbo comes with a 3inch inlet compressor housing and the arc box is smaller then at its utmost flow range there will be a restriction regardless of box or not Link to comment Share on other sites More sharing options...
Gaz6002 Posted June 18, 2008 Share Posted June 18, 2008 I assumed you were bpu If the filter is not of paper origin then any aftermarket filter with a decent filter element(not HKS) and a heat sheild will do the same job If your turbo comes with a 3inch inlet compressor housing and the arc box is smaller then at its utmost flow range there will be a restriction regardless of box or not Have you got one? Can you tell me how big the inlet is? Link to comment Share on other sites More sharing options...
bolarbag Posted June 18, 2008 Share Posted June 18, 2008 Have you got one? Can you tell me how big the inlet is? No I personally think its a gimmic, pretty but pointless Link to comment Share on other sites More sharing options...
steb9780 Posted June 18, 2008 Share Posted June 18, 2008 There's some pictures of them here. I didn't know they did another one the v2 or something. http://www.envyperformance.com/index.cfm?fuseaction=category.display&category_id=17 Link to comment Share on other sites More sharing options...
Swampy442 Posted June 18, 2008 Share Posted June 18, 2008 Ive got one of these on mine http://www.envyperformance.com/index.cfm?fuseaction=product.display&Product_ID=6062 Whether or not its better than the stock airbox only a dyno will tell. However I like it, it sounds great too Link to comment Share on other sites More sharing options...
bmx1lew Posted June 19, 2008 Share Posted June 19, 2008 Ive got one of these on mine http://www.envyperformance.com/index.cfm?fuseaction=product.display&Product_ID=6062 Whether or not its better than the stock airbox only a dyno will tell. However I like it, it sounds great too Would you take pic's I really want one, bit over priced. Link to comment Share on other sites More sharing options...
colsoop Posted June 19, 2008 Share Posted June 19, 2008 The whole front face is open so it is less restrictive in that respect. You would need a good feed of air to make the most of that though. It is a well made bit of kit. One point to note replacement filters are circa £50 ! Link to comment Share on other sites More sharing options...
Jellybean Posted June 19, 2008 Author Share Posted June 19, 2008 The whole front face is open so it is less restrictive in that respect. You would need a good feed of air to make the most of that though. It is a well made bit of kit. One point to note replacement filters are circa £50 ! They Last for 15 K Miles so probably work out the same as replacing Standard filter every Service Link to comment Share on other sites More sharing options...
iain2010 Posted June 19, 2008 Share Posted June 19, 2008 Ive just ordered one from Nic. Mines only an NA but ill let you know what i think. Not sure how it will compare to the standard induction box but has got to be better than the universal open "max power" type induction cone i have on at the moment Link to comment Share on other sites More sharing options...
Jellybean Posted June 19, 2008 Author Share Posted June 19, 2008 Ive just ordered one from Nic. Mines only an NA but ill let you know what i think. Not sure how it will compare to the standard induction box but has got to be better than the universal open "max power" type induction cone i have on at the moment Keep me posted, one of the Guys in US has one coming soon and is going to do a review too http://www.supraforums.com/forum/showthread.php?t=496018&goto=newpost Link to comment Share on other sites More sharing options...
bmx1lew Posted June 19, 2008 Share Posted June 19, 2008 well im currently using the HKS mushroom filter, but due to the bad tests results i really want to change, was thinking apexi but seen as i want to bling up the engine bay why not get a few blingy bits but obviously the ARC is a good bit of kit aswell Link to comment Share on other sites More sharing options...
iain2010 Posted June 19, 2008 Share Posted June 19, 2008 Keep me posted, one of the Guys in US has one coming soon and is going to do a review too http://www.supraforums.com/forum/showthread.php?t=496018&goto=newpost Will do mate. Link to comment Share on other sites More sharing options...
