Turbo Drain & Smoke?
Tricky-Ricky
In relation to my intermittent smoke problem on my single install, i just took off the turbo and had a look, and its looking like there is still a slight leak from the drain flange from the turbo, checked the face, which i thought i had already done, and found it to be a little distorted, so i will sort it with a file and bolt it all back together, but what i want to ask is has anyone with a single experienced this? my theory is that the slight leak allows oil to hang around the exhaust housing flange and on the overrun it gets drawn into the housing and burnt, causing smoke? what do you think?
