cheekymonkey Posted June 17, 2008 Share Posted June 17, 2008 I have a couple more gadgets in my car since I last went to Santa Pod... and I would appreciate some hints on how best to use them! I have RLTC with Launch Control and a Line lock kit (sadly still on a stock clutch though ) However I'm not sure how best to use these for a good launch! Where should I set the launch control rev-limit? I've set it at just over 4k so that the car is on boost for launch, but I still get wheelspin. This is with the RLTC set to Dry mode. Any ideas from the experts? Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted June 17, 2008 Share Posted June 17, 2008 I am looking forward to testing my line lock kit at the pod soon, I would have thought your stock clutch will be tested to its limit by drag launches and line lock tyre warm ups however, hope it holds out Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted June 17, 2008 Share Posted June 17, 2008 Use the link lock to lock the fronts for a big burnout. Then set launch control for desired launch RPM (will be slightly higher than on road as friction will be higher after burnout) and go go buffalo! Easy Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted June 17, 2008 Share Posted June 17, 2008 Your car is making good power, your clutch will not like it. You may get away with a few launches though... Quote Link to comment Share on other sites More sharing options...
cheekymonkey Posted June 17, 2008 Author Share Posted June 17, 2008 Thanks guys! Will probably take a couple of goes to get a feel for it so I hope the clutch lasts Quote Link to comment Share on other sites More sharing options...
