bolarbag Posted June 17, 2008 Share Posted June 17, 2008 It is to test the compression in all the 6 cylinders to see if the thing's *uggered Yeah that, and is T88 Turbo as bad as everyone says it is. If this is your first, your impression of a supra will not be as most, it is extremely laggy and pretty pointless If you have a T04 flange, take it off and fire on either a T67dbb or if your looking to only use it on the streets a GT35R With a Kit like that it has to be a big cruiser so T67dbb is your best bet I gather you have cams to suit, other wise that T88 will be pretty pointless Quote Link to comment Share on other sites More sharing options...
allawyg Posted June 18, 2008 Author Share Posted June 18, 2008 Yeah that, and If this is your first, your impression of a supra will not be as most, it is extremely laggy and pretty pointless If you have a T04 flange, take it off and fire on either a T67dbb or if your looking to only use it on the streets a GT35R With a Kit like that it has to be a big cruiser so T67dbb is your best bet I gather you have cams to suit, other wise that T88 will be pretty pointless wow I didnt know its like that, yea do u think I should change the turbo, if so what do u recomment. What cams do I need, everyone has been telling me that stock cams are good enough. please tell me more, cheers Quote Link to comment Share on other sites More sharing options...
bolarbag Posted June 18, 2008 Share Posted June 18, 2008 What cams do I need, everyone has been telling me that stock cams are good enough. please tell me more, cheers If your car is a j-spec their definitely not, even the UK's strangle power in anything but a very small single T67dbb or GT4088R, for a big cruiser a GT35R will not be as impressive as it runs out of legs around 5500rpm Quote Link to comment Share on other sites More sharing options...
allawyg Posted June 18, 2008 Author Share Posted June 18, 2008 nice one mate ill look into it, see what I can afford. what about cams, what do you recommend that I change, all the pullies n belts? what make? Do I need to change the camshaft itself as well? I appreciate ur help.. im such a newb Quote Link to comment Share on other sites More sharing options...
allawyg Posted June 18, 2008 Author Share Posted June 18, 2008 also do I need an uprated alternator and waterpump or is stock ok? Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted June 18, 2008 Share Posted June 18, 2008 also do I need an uprated alternator and waterpump or is stock ok? Hi again mate Like I said in my first post you need to slow down a bit and take stock of what you have, there is no right and wrong spec as such but many different things you can do to get your car running again, you will require deep pockets if you start changing too many things right now, can I ask again who is working on the car for you, do they understand single Supras, if not the first thing I would do is get it to a specialist, we can suggest several in London/Essex etc I am in Purfleet in Essex if you want to come over for a chat and discuss a few options, I am not mechanic but have owned a few singles in my time, I would be more than happy to talk your option through, there are several guys on here who would make some very wise choices with regards to where you should go with the spec etc This should come out of MKIV Tech I would have thought and go to Chat ? Quote Link to comment Share on other sites More sharing options...
bolarbag Posted June 18, 2008 Share Posted June 18, 2008 (edited) nice one mate ill look into it, see what I can afford. what about cams, what do you recommend that I change, all the pullies n belts? what make? Do I need to change the camshaft itself as well? I appreciate ur help.. im such a newb You should change the timing belt, you do not need to change the pulley's unless your ones are fecked Stock water pump and alternator are good, Cams = camshafts?? The spec is up to you but a lot of folk have seen good gains with HKS 264in. 264exh, or for more response, a staggered combo like 256in. 264exh. HKS cams are pretty reliable and still retain the non-interference feature of the 2JZ, again for a big cruiser, you should do well with 264/264's Do you mean crankshaft - if so no, you do not need to change that - again unless its fubbared, I'd be doing a compression test and leak down test before I spend anything on the car, Edited June 18, 2008 by bolarbag (see edit history) Quote Link to comment Share on other sites More sharing options...
allawyg Posted June 18, 2008 Author Share Posted June 18, 2008 Hi again mate Like I said in my first post you need to slow down a bit and take stock of what you have, there is no right and wrong spec as such but many different things you can do to get your car running again, you will require deep pockets if you start changing too many things right now, can I ask again who is working on the car for you, do they understand single Supras, if not the first thing I would do is get it to a specialist, we can suggest several in London/Essex etc I am in Purfleet in Essex if you want to come over for a chat and discuss a few options, I am not mechanic but have owned a few singles in my time, I would be more than happy to talk your option through, there are several guys on here who would make some very wise choices with regards to where you should go with the spec etc This should come out of MKIV Tech I would have thought and go to Chat ? Hi mate, well I got my mate whos a good mechanic, hes not a specialist in turbo cars, Im only getting him to fit parts then I need to find a specialist for fine tunning, I live in London so if you could recommned me where to go that would be great. Appreciate your offer to meet n chat, I might take u up for that sometime soon if im around in essex yea I think a lot of people have been telling me not to go out n spend stupid money, I might just get it running and give it a good service then take it to a specialist to get the ecu mapped and see what advice he gives me. appreciate your advice Quote Link to comment Share on other sites More sharing options...
allawyg Posted June 18, 2008 Author Share Posted June 18, 2008 You should change the timing belt, you do not need to change the pulley's unless your ones are fecked Stock water pump and alternator are good, Cams = camshafts?? The spec is up to you but a lot of folk have seen good gains with HKS 264in. 264exh, or for more response, a staggered combo like 256in. 264exh. HKS cams are pretty reliable and still retain the non-interference feature of the 2JZ, again for a big cruiser, you should do well with 264/264's Do you mean crankshaft - if so no, you do not need to change that - again unless its fubbared, I'd be doing a compression test and leak down test before I spend anything on the car, yea my pullies are f'd, Im gonna use stock pullies and might get the hks timing belt pullies jus to be on safe side. camshaft ill do that next month I think. I dont know what the numbers mean but ill got for the hks ones 264/264 like u said, then I should be good thanks again... All u guys been great crankshaft is fine, Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted August 1, 2008 Share Posted August 1, 2008 Last engine I saw with an alternator that had sheared or fallen off the block had been involved in a 90 mph smash into a lampost Only way to get that back on is to cast weld it or at least thats what I was told at the time. Thats why I gave that engine gratis to dude who did in fact know someone that could cast weld. Quote Link to comment Share on other sites More sharing options...
