Riddle me this...
Gaz6002
  • Replies 350
You have a barrel of oil, and you need to measure out just one gallon. How do you do this if you only have a three-gallon container and a five-gallon container?
Fill up the 5 gallon container then empty into the three gallon container, then empty the three gallon container into the barrall, you then have 2 gallons in the five gallon container so empty the two gallons into the three gallon container, you then fill up the five gallon container and pour into the three gallon container leaving four gallons in the five gallon you then empty the three gallon container and pour three gallons into the three gallon container and you are left with one gallon in the five gallon container. Phew....
Two strangers from different parts of America both build simular apartment buildings in their home towns. By chance, they both forget an important part of thier project. They each, once again by chance, call the same national hardware store and order the missing items. The prices they are quoted are as follows:
one will cost them $2.
two will cost them $2.
twelve will cost them $4.
and a hundred and fourty-four will cost $6.
What was the item they needed?
A fool wants to tie a rope around the earth. So he buys a rope of 40,000 KM and ties it around the world. His neighbour, also a fool, wants to do the same only he wants the rope on sticks 1 meter above the ground.
How much more rope does he need?
And how much more rope do you need when you use a tennis ball instead of the earth?
8=7
9=6
well done. i made that one up so there could be no searching online for an answer - (not that anyone on here would do that ;))
Mountains will crumble and temples will fall, and no man can survive its endless call. What is it?
= time
