Fully decatted and still only seeing stock boost
miko_supra
Done all my BPU parts...
double 3" decat
48mm restrictor ring
Greddy BCC
Spark plugs
no uprated fuel pump yet as it hasnt arrived.
Took it out for a drive and although it feels more responsive i am seeing the exact same boost levels as i did before. (10 psi)
I put the car into TTC mode http://www.internetwork.org.uk/ttc/ttc.htm to see if i could see a higher boost, but when i did this it boosted to around 7 psi and then dropped at higher rpms to around 4psi....
Ideas anyone?
Make the hole bigger in the restrictor ring then.
Do you have a UK spec TT conversion or Jap spec?
Its a j-spec TT, I've taken that exhaust on and off like 10 times in the past week so i think i might buy a manual boost controller for a few quid instead of pissing around with the restrictor ring...anyone have a guide on fitting these?
Not all j-specs overboost or increase boost when decatted. I had this with my first supra when decatted and everyone jumped on the bandwagon thinking that there was something wrong but i very much doubt it. Try a EBC and see how you get on or as carl0s said, use a bigger rest. ring.
  • 2 weeks later...
Exactly the same with me Kosmic, only when i put hybrids on and an EBC did it increase....frustrating i know but not all supra's act the same.
I wonder if you have a fuel delivery issue, have you changed the fuel filter?? also perhaps your fuel pump is having a problem supplying the fuel, do you have an AFR gauge, if so are you going lean??
I would not risk going without the restrictor ring, you shound be making 1.2 bar with this in
An AFR gauge is next on my list of items to get, but i'm not sure which one to get
Hi miko,
I noticed you posted on my thread that you were having similar problems: http://mkivsupra.net/vbb/showthread.php?t=139860
I've not done anything with it yet just been enjoying my 1 bar of boost. When you ran it without the RR and boost controller were you still not getting anywhere 1.2 bar?
I think I need to get myself a boost controller and give it a bash.
