miko_supra Posted June 15, 2008 Share Posted June 15, 2008 Done all my BPU parts... double 3" decat 48mm restrictor ring Greddy BCC Spark plugs no uprated fuel pump yet as it hasnt arrived. Took it out for a drive and although it feels more responsive i am seeing the exact same boost levels as i did before. (10 psi) I put the car into TTC mode http://www.internetwork.org.uk/ttc/ttc.htm to see if i could see a higher boost, but when i did this it boosted to around 7 psi and then dropped at higher rpms to around 4psi.... Ideas anyone? Quote Link to comment Share on other sites More sharing options...
carl0s Posted June 15, 2008 Share Posted June 15, 2008 Make the hole bigger in the restrictor ring then. Do you have a UK spec TT conversion or Jap spec? Quote Link to comment Share on other sites More sharing options...
carl0s Posted June 15, 2008 Share Posted June 15, 2008 Is your second turbo actually working BTW? Quote Link to comment Share on other sites More sharing options...
Trig Posted June 15, 2008 Share Posted June 15, 2008 miko what ever happened to your wheel jumping issue? did you get it sorted? Im doing my conversion within the next month hopefully, think i might have to pick your brains a few times Quote Link to comment Share on other sites More sharing options...
miko_supra Posted June 15, 2008 Author Share Posted June 15, 2008 Is your second turbo actually working BTW? yeah second turbo is working fine Quote Link to comment Share on other sites More sharing options...
miko_supra Posted June 15, 2008 Author Share Posted June 15, 2008 miko what ever happened to your wheel jumping issue? did you get it sorted? Im doing my conversion within the next month hopefully, think i might have to pick your brains a few times http://mkivsupra.net/vbb/showthread.php?t=140356&highlight=project+starts+today Quote Link to comment Share on other sites More sharing options...
miko_supra Posted June 15, 2008 Author Share Posted June 15, 2008 Make the hole bigger in the restrictor ring then. Do you have a UK spec TT conversion or Jap spec? Its a j-spec TT, I've taken that exhaust on and off like 10 times in the past week so i think i might buy a manual boost controller for a few quid instead of pissing around with the restrictor ring...anyone have a guide on fitting these? Quote Link to comment Share on other sites More sharing options...
Scott Posted June 15, 2008 Share Posted June 15, 2008 Dead easy, either cut the actuator hose and plumb in the MBC or get a piece of hose identical and plumb it in without the cutting (the best way) Quote Link to comment Share on other sites More sharing options...
kosmic Posted June 15, 2008 Share Posted June 15, 2008 Not all j-specs overboost or increase boost when decatted. I had this with my first supra when decatted and everyone jumped on the bandwagon thinking that there was something wrong but i very much doubt it. Try a EBC and see how you get on or as carl0s said, use a bigger rest. ring. Quote Link to comment Share on other sites More sharing options...
miko_supra Posted June 25, 2008 Author Share Posted June 25, 2008 Ok i fitted a manual boost controller...i wound it all the way out as far as i could but i have only seen a 1-1.5 psi increase.... Quote Link to comment Share on other sites More sharing options...
miko_supra Posted June 25, 2008 Author Share Posted June 25, 2008 Hang on...school boyed it...i've fitted the controller the wrong way around...i'll refit that and update this thread when i drive it again later Quote Link to comment Share on other sites More sharing options...
miko_supra Posted June 25, 2008 Author Share Posted June 25, 2008 Taken it out for another drive with the controller the right way around and there is still not different (just the 1 psi increase) Quote Link to comment Share on other sites More sharing options...
ADD Posted June 25, 2008 Share Posted June 25, 2008 Not all j-specs overboost or increase boost when decatted. I had this with my first supra when decatted and everyone jumped on the bandwagon thinking that there was something wrong but i very much doubt it. Try a EBC and see how you get on or as carl0s said, use a bigger rest. ring. Exactly the same with me Kosmic, only when i put hybrids on and an EBC did it increase....frustrating i know but not all supra's act the same. Quote Link to comment Share on other sites More sharing options...
D8MOA Posted June 25, 2008 Share Posted June 25, 2008 what exhaust are you running? maybe to restrictive? Quote Link to comment Share on other sites More sharing options...
miko_supra Posted June 25, 2008 Author Share Posted June 25, 2008 what exhaust are you running? maybe to restrictive? Im running a hks silent high power. Its just the one silencer at the box (no mid box) Think im going to try it next with no restrictor ring in at all Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted June 25, 2008 Share Posted June 25, 2008 I wonder if you have a fuel delivery issue, have you changed the fuel filter?? also perhaps your fuel pump is having a problem supplying the fuel, do you have an AFR gauge, if so are you going lean?? I would not risk going without the restrictor ring, you shound be making 1.2 bar with this in Quote Link to comment Share on other sites More sharing options...
miko_supra Posted June 25, 2008 Author Share Posted June 25, 2008 I wonder if you have a fuel delivery issue, have you changed the fuel filter?? also perhaps your fuel pump is having a problem supplying the fuel, do you have an AFR gauge, if so are you going lean?? I would not risk going without the restrictor ring, you shound be making 1.2 bar with this in An AFR gauge is next on my list of items to get, but i'm not sure which one to get Quote Link to comment Share on other sites More sharing options...
miko_supra Posted June 27, 2008 Author Share Posted June 27, 2008 i've taken the restrictor ring out and it's now boosting spot on 18psi Quote Link to comment Share on other sites More sharing options...
JohnnyW Posted June 27, 2008 Share Posted June 27, 2008 Hi miko, I noticed you posted on my thread that you were having similar problems: http://mkivsupra.net/vbb/showthread.php?t=139860 I've not done anything with it yet just been enjoying my 1 bar of boost. When you ran it without the RR and boost controller were you still not getting anywhere 1.2 bar? I think I need to get myself a boost controller and give it a bash. Quote Link to comment Share on other sites More sharing options...
Billy Posted June 27, 2008 Share Posted June 27, 2008 fitted chris wilson double de cat pipes and nur spec r to my supe and it still only boosted to 0.9 bar had to fit bleed T to get it to 1.2 bar Quote Link to comment Share on other sites More sharing options...
