miko_supra Posted June 14, 2008 Share Posted June 14, 2008 underneath my car i noticed this... looks like its coming from around the oil line Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted June 14, 2008 Share Posted June 14, 2008 Probably a loose nut, or failing that replace the gasket. Quote Link to comment Share on other sites More sharing options...
ADD Posted June 15, 2008 Share Posted June 15, 2008 I had this mate a while ago, the tubby gasket had gone!! just replace it mate Quote Link to comment Share on other sites More sharing options...
miko_supra Posted June 15, 2008 Author Share Posted June 15, 2008 thanks guys Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 16, 2008 Share Posted June 16, 2008 A right PITA to do in situ without a ramp and some good 3/8 and 1/4 drive wobble sockets. Quote Link to comment Share on other sites More sharing options...
miko_supra Posted June 16, 2008 Author Share Posted June 16, 2008 A right PITA to do in situ without a ramp and some good 3/8 and 1/4 drive wobble sockets. So is it just that gasket where the oil line goes into the turbo the needs replacing yeah? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 17, 2008 Share Posted June 17, 2008 Hard to say from a photo, power wash it all off and see if you can isolate the leak, or just risk changing the gasket. the pipes need freeing at both ends and at the support clips, and access is very limited, especially if you have to do it on your back. Quote Link to comment Share on other sites More sharing options...
miko_supra Posted June 17, 2008 Author Share Posted June 17, 2008 Hard to say from a photo, power wash it all off and see if you can isolate the leak, or just risk changing the gasket. the pipes need freeing at both ends and at the support clips, and access is very limited, especially if you have to do it on your back. It will be an axle stand jobby thats for sure Thanks for the advise chris Quote Link to comment Share on other sites More sharing options...
