My new aero top
P4U1
I have an aero top supra which makes loads of noise from the roof when you are driving, i think the car has particularly hard suspension which doesnt help, but i think the rubbers etc need replacing as the roof panel isnt coping with the movement you get, at least not quietly
Can anyone help? Is it possible to have an aero top supra which when driving makes no noise?
Ta
Paul
  • 1 month later...
Ta
Paul
Just seen this post. I have an aerotop that doesn`t rattle and the bolts also do not need to be tightened every few miles. My last aerotop did rattle and did need tightening every now and again. So I guess its just luck of the draw!!
Ian
My experience is that if you take care and park the car on even ground when you fasten your roof, it can go many months before you have to tighten the screws. But..if you put on the roof when parked just a little bit off of even ground...youll have to tighten the screws very often :)
